Re: Moving up to Jesel
[Re: AndyF]
#33978
03/14/07 06:26 PM
03/14/07 06:26 PM
Hey I am new to this site and have been following your comments on Jessel. First of all thanks very much for the great pictures on installing the Jessel rockers.
I was lost after talking to Indy, as said before they aren't much help.
I have a couple of questions if you guys could help I would appreciate it.
1) I am going to have push rod oiling with bushed lifter bores. Anyone else running the same and if so is there any concerns? Jessel said it should be okay but I forgot to mention that the lifter bores were bushed (only a 0.060" feed hole)
2) Does anyone have any instructions or pictures on a spray bar install.
[Re: AndyF]
#33980
03/14/07 07:46 PM
03/14/07 07:46 PM
Thanks for the quick response. The pictures of the spray bars would be great! I got my kit from Indy.
If the oil feed hole is in the right location when the valve is closed but not in lift is that a problem?
I actually have to put it together to check and see where things line up.
[Re: AndyF]
#33982
03/16/07 12:23 PM
03/16/07 12:23 PM
Hey andy any luck on the spray bar pictures?
[Re: RT540]
#33984
03/16/07 12:36 PM
03/16/07 12:36 PM
Thanks for the picture. What does the other side look like? Do you run a baffle under your breather?
Very Nice looking Coronet by the way.
#33985
03/16/07 01:43 PM
03/16/07 01:43 PM
Posts: 1,664 North Sweden
RT540
North Sweden
Thanks No breather, the other side looks the same, I have a dry sump oil system.
