Time to plumb and wire - any pics for ideas??
#338713
06/05/09 02:15 PM
06/05/09 02:15 PM
Posts: 876 Arizona
PolyDart
Arizona
I'm starting from scratch. Using a Magnafuel pump, 4 wheel disc brakes, and a Painless race wiring panel/harness. I would like to see your setups to get an idea of how you routed your stuff. The more pics the better! Photos from this site have been VERY valuable to my build up to this point. Thanks!!
Re: Time to plumb and wire - any pics for ideas??
[Re: PolyDart]
#338714
06/05/09 02:17 PM
06/05/09 02:17 PM
Quicktree
[Re: bigdad]
#338720
06/05/09 06:06 PM
06/05/09 06:06 PM
Posts: 34,934 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
those are all on Joes car .. Airpushbuttons
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#338722
06/05/09 06:11 PM
06/05/09 06:11 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I made a spot for all my fuel lines to run , I also have a return line ..pita
[Re: bigdad]
#338723
06/05/09 06:12 PM
06/05/09 06:12 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Thru the rockers, under the fenders
[Re: bigdad]
#338726
06/05/09 06:32 PM
06/05/09 06:32 PM
Posts: 876 Arizona
PolyDart
Arizona
I like that a lot
[Re: PolyDart]
#338727
06/05/09 07:16 PM
06/05/09 07:16 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I have all my stuff hidden fairly well, makes for a nice clean look .. I've seen your work, I'm sure you will have no problem out doing me I have more pics if you need to see anything else "a place for everything and, everything in its place"
[Re: PolyDart]
#338729
06/05/09 08:16 PM
06/05/09 08:16 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Yes ..
-10 up and back , Kyle Fickler then worked for Aeromotive and told me how it should be done
Notice, fliter AFTER the pump, I asked over and over are you SURE ?? Yep ..Not even a pre=screen ??Nope ,cause air bubbles
buttttt..Your instructions say ????
Ignore it do it this way ??
So, it will cause a fight , and I don't even like to post tech anymore cause everyone has there way ..
I did it the way he told me ..
Re: Time to plumb and wire - any pics for ideas?? *DELETED*
[Re: bigdad]
#338730
06/07/09 02:24 PM
06/07/09 02:24 PM
Posts: 876 Arizona
PolyDart
Arizona
[Re: PolyDart]
#338731
06/07/09 02:59 PM
06/07/09 02:59 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
I didn't wire my cuda, so I can't help with that. I will offer a couple suggestions though, consider servicing it! Examples are a loop of all the dash wires and all the switch panel wires, so they can be hung down and swivelled for service. Wire the components (water pump, Alt, starter, Dist, Fuel pump, etc.) so you can remove them and set them aside without disconnecting. Don't have the wires going in 2 different directions if possible. Make sure low level signal wires are not bundled with high amp or high noise wires. The ignition should not be bundled with the alt, fuel pump, water pump. On items where the common diagnosis is "replace with known good unit and retest" like ignition modules and relays, consider how easily they can be replaced. If you are using any small sub-harnesses like a fan connector, the standard is to run the hot wire to the female connector, so when it's disconnected, it can't short out. Mount wiring so it can be checked with a test light without moving the component if possible.
Most race cars are wired without main harness connectors. If you are doing that, make sure you will be able to trace each wire. You don't want to have to disconnect everything on that end of the harness to pull it out enough to diagnose. If you do use main connectors, split them up to have all the heavy circuits on one and the low circuits on another. Again, have the female connector on the hot side.
Have all the fuses in one or two locations, and make sure you have extras easily at hand. If you are in the staging lanes for the final, a big assortment in the trailer won't help.
Consider what would happen if the heavy wires do short. Don't tie wrap them to a fuel hose, or where the heat will cause more issues. Try to avoid heat and vibration where you can.
[Re: bigdad]
#338733
06/08/09 10:26 AM
06/08/09 10:26 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
This is like the tube/no tube in slicks discussions.
I'm running a A-1000pump with a 100 micron filter on the inlet side, 10 micron on the outlet side. 10AN up, 8AN back on an EFI system.
I've had problems with cavitation, should I remove the 100 micron pre filter?
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: bigdad]
#338734
06/15/09 10:31 PM
06/15/09 10:31 PM
Posts: 876 Arizona
PolyDart
Arizona
My trunk area ..
Bigdad, it's hard to tell from the photo, is your fuel cell set up like this?
I was just wondering if you're running slightly up hill to get fuel from your cell to the pump.
[Re: bigdad]
#338738
07/09/09 05:18 PM
07/09/09 05:18 PM
Posts: 876 Arizona
PolyDart
Arizona
[Re: PolyDart]
#338739
07/09/09 05:38 PM
07/09/09 05:38 PM
Quicktree
[Re: Quicktree]
#338740
07/09/09 05:43 PM
07/09/09 05:43 PM
Posts: 876 Arizona
PolyDart
Arizona
hey where did you get the idea of the sliding tray
Your install of course That really is a slick setup. I'm glad you shared it with the site.
[Re: PolyDart]
#338741
07/09/09 05:49 PM
07/09/09 05:49 PM
Quicktree
no problem glad I could help. keep us posted it's looking good.
[Re: Quicktree]
#338742
07/18/09 08:10 PM
07/18/09 08:10 PM
Posts: 876 Arizona
PolyDart
Arizona
