Re: What is a good way to remove stock bellhousing dowels?
[Re: Bill MeLater]
#337754
06/03/09 11:43 PM
06/03/09 11:43 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
Mine were stuck pretty good so I drilled and tapped 'em and stck a lugnut and washer over 'em and threaded a bolt in to pull 'em out. Worked like a charm
That does work , the dowel is soft enough to be drilled and tapped , the correct way is with a dowel pin puller but they aren't cheap to buy . I did the same thing pulling head dowels
[Re: Exit1965]
#337758
06/04/09 06:17 PM
06/04/09 06:17 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I ended up drilling mine out.gotta be careful that you drill on center though, and don't cut into the block at all. I think they are a 1/2" hole? I went with a drill bit that was just smaller than the dowels. as I got into the dowel, it gave up it's "outward push" against the block, and came right out.
**Photobucket sucks**
