Re: Carb question
[Re: 68CoronetRT]
#337439
06/03/09 08:09 PM
06/03/09 08:09 PM
RapidRobert
how many turns is your idle speed screw turned in? What eng/cam/idle speed?
Re: Carb question
[Re: RapidRobert]
#337440
06/03/09 08:22 PM
06/03/09 08:22 PM
Posts: 826 Stone Mt, GA.
DEMONSIZZLER
super gas
super gas
Stone Mt, GA.
Good point R; if you had to idle the carb up excessively to get a steady idle speed, you are off or transitioning from the idle circuit to the main circuit. You will likely need to bump up your initial timing a few degrees which will increase idle speed, then back off your idle speed accordingly. This will give you back your idle circuit and its adjust-ability with the idle mix screws, David.
ThermoQuads:stock, street/strip and race;
800/850 cfm's, 860/910 cfm's and 1,000 to 1,060 cfm's.
New parts for all OEM 1971-1984, Competition Series and SuperQuad carbs and custom fabricating.
Carbs bought and sold. Consulting on pre-purchases
so you get the right carb the first time.
Re: Carb question
[Re: 68CoronetRT]
#337442
06/04/09 11:39 PM
06/04/09 11:39 PM
RapidRobert
what is not working right other than the mixture screws having no effect as something has to be out of whack. I would open up the carb & look for something that isn't right.
Re: Carb question
[Re: 68CoronetRT]
#337446
06/05/09 10:39 PM
06/05/09 10:39 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
If you have to prime it? Either the O rings aren't sealing or the jet wells are leaking. The jet wells will cause a need to prime and a rich condition.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
