Re: 56 Chrsyler engin swap ???
[Re: THESHAKERPROJECT]
#336302
06/02/09 06:38 PM
06/02/09 06:38 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The Chrysler Hemi is a relation to the A and LA motors so those would likely be the best fit, but then the new Hemi's are related to the LA engines, so you could close the circle and put a new Hemi in to replace that old Whale engine.
Nothing is gonna be a easy drop in replacement other than another old Hemi but the enignes I mention aren't too bad.
[Re: Supercuda]
#336303
06/03/09 02:10 AM
06/03/09 02:10 AM
Posts: 1,295 Hawley, Texas
shinnery
super street
super street
Hawley, Texas
This could get to be a interesting swap as no modern engine's crankshaft will bolt to his cast iron PowerFlite or TorqueFlite tranny. If you change trannys the push buttons won't work and you lose your parking brake, etc, etc. Time for some planning. Bryce
Every electronic device is manufactured with smoke stored deep inside...
only a true genius can find a way to set it free.
The most terrifying words in the English language are: "I'm from the government and I am here to help!"
[Re: 76dodgeboy]
#336305
06/03/09 02:24 PM
06/03/09 02:24 PM
Posts: 21,071 Niles , Ohio
therocks
Niles , Ohio
You can use the later TF with posh button.If you find a 62 I know they have the park brake on the trans,My kids is sitting in the garage from his 62 300.Later years had the park pawl in the push button trannys.Rocky
Chrysler Firepower
[Re: therocks]
#336306
06/04/09 01:28 PM
06/04/09 01:28 PM
Supercuda
About to go away
About to go away
up yours
I believe Imperial Services makes a setup to allow a modern Torqueflite to work with the older pushbutton setup. Not sure if a 56 is one of them though, google is your friend.
[Re: Supercuda]
#336307
06/07/09 01:27 AM
06/07/09 01:27 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
As already mentioned, there is more to this than just the engine. That said, the LA is pretty much able to be bolted to the enginr mounts. If an OE-ish trans is not used then the rear is likely going to require changing to a later unit. If he wants to keep the original rear, then the best bet (IMHO) is to go to an AAJ Brakes rear disc kit with e-brake. Bolts right to the original stuff. I danced with the idea, some time ago, of an electronically controlled valve boy activated by the original buttons in the pushbutton control. I have NO idea how feasible it was, though...
2 Demons...no, not my kids!
