Re: Any 400 builds here? (non stroker)
[Re: DusterKrazy]
#335955
06/02/09 02:21 AM
06/02/09 02:21 AM
RapidRobert
I'm just starting on one: 400 blk, 440crank/rods, KB 280 pistons(451) undecided on heads, I want some stealths.
[Re: RapidRobert]
#335956
06/02/09 02:32 AM
06/02/09 02:32 AM
DaytonaTurbo
Manitoba, Canada
That's a good build. If you check out the for sale section on here you can get a used 440 crank for very cheap and build yourself a 451 for barely any more $ than a stock stroke 400 would have costed. 51 cubes for a few $ sounds like a good deal to me IMO.
[Re: RapidRobert]
#335958
06/02/09 08:26 AM
06/02/09 08:26 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
andyF built a stock stroke 400 a few years ago that put out ~580HP through an 800 eddie carb. IIRC it had eddie heads and a solid roller cam.
[Re: RapidRobert]
#335959
06/02/09 08:57 AM
06/02/09 08:57 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
451 is a very good motor. Since all the 440 guys are going BIG you should be able to find a crank for a decent price. Make sure you put a 383 pie tin on the car....
[Re: Mr.Yuck]
#335962
06/02/09 09:34 AM
06/02/09 09:34 AM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
Glad to see everyone telling the guy what he didn't want to hear Unless you can find a 440 crank for next to nothing and then can get it machined very cheaply it make no sense not to buy a stroker crank , if it's about saving money check ebarf , hawks racing sells stroker cranks CHEAPER than the other guy , same .. cough cough ... quality ... cough cough , hundred bucks less
[Re: JohnRR]
#335963
06/02/09 10:57 AM
06/02/09 10:57 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
hey guys, GUUUYS, don't miss the deal here. HE IS NOT THINKING on build an stroker. NOT EVERY 400 NEEDS TO BE STROKED!!!
if you get the earliers 383 CR, what is pretty much easy changing the pistons you should be close to 330 HP, like earliers 383, maybe little bit more due the increased displacement and the spreadbore carb disposition.
so go with KB240 pistons, metalick headgasket, HP camshaft and you are done... should get same 383 power or little bit more.
The HP cam is not really a requirement since earliers 400 magunms got same 383 and 440 camshafts, but, $130-160 more investment won't hurt and will be noticeable. since 74 400 magnums got the basic camshaft
if you want little bit more, port and slightly mill the heads. 383 got power also with OPEN HEADS soooo no need to change the heads either, but if you have acces to closed, that will be fine!!!, an advice is install hardened valve seats. Maybe don't really needed but better just in case.
383 and 400 are same engines but bigger and lower pistons... change the pistons height and VOILA.
not everyone wants to race!!!!
I'm going right now with same pistons and camshaft upgrades and some job on heads
[Re: NachoRT74]
#335964
06/02/09 11:08 AM
06/02/09 11:08 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
My sons Dart is a stock stroke .030 over 400 (406). KB pistons and Eddy heads with 10.6 comp and MP .557 cam. RPM intake and a 750 DP with CPPA 2" headers. In his 72 Dart that goes 3550 with him in it. It has a 9.5 Dynamic converter and 3.91's. With Hoosier QTP 26 x 9.5 tires he has run 11.45 @ 117 best. Yea you dont always have to stroke a 400. Ron
[Re: NachoRT74]
#335965
06/02/09 12:26 PM
06/02/09 12:26 PM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
if you want little bit more, port and slightly mill the heads. 383 got power also con OPEN HEADS soooo no need to change the heads either, but if you have acces to closed, that will be fine!!!, an advice is install hardened valve seats. Maybe don't really needed but better just in case.
Good advice there. Yes I already have the '65 383 closed chamber heads and also I have the 383 steel crank as well. Dont know if Id ever have a use for it but it's there in case because Id have it balanced anyways.
Gonna look at cams that will give strong low end torque to.
[Re: DusterKrazy]
#335966
06/02/09 02:32 PM
06/02/09 02:32 PM
Posts: 1,647 IL
71383beep
IL
I would build it like a 383. Use the closed chamber heads and get a cam in the 230 to 240ish @ 0.050 range a good intake and carb, headers, and it shoudl be an easy 430/460 hp/tq motor. Compression is the issue and open chamber heads are harder to work with in this regard.
Assuming it's a cast crank you can go up to 500 hp easily. If you had a forged 383 crank laying around I would use it for insurance, but the cast is fine for mild builds...just creates some unique balance issues during the build. No big deal really becasue it is good insurance to nuetral balance the rolling assembly anyways.
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: 71383beep]
#335967
06/02/09 02:50 PM
06/02/09 02:50 PM
DusterKrazy
N.Wilkesboro,NC
Exactly what Im thinking. I scored a single plane weiand intake the other day for $50. I could run that with a 1 inch 4 hole spacer along with the appropriate carb and be set in that department.
Then add closed chamber heads with hardened seats and a good three angle valve job. Then headers and the other typical bolt on hot rod stuff. Windage tray etc.
Looking at cams to maximize low end torque as well..
[Re: DusterKrazy]
#335968
06/02/09 02:53 PM
06/02/09 02:53 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Turning an apple into an orange?
[Re: RemCharger]
#335969
06/02/09 03:43 PM
06/02/09 03:43 PM
DusterKrazy
N.Wilkesboro,NC
MMMMM...oranges
[Re: mike s]
#335971
06/02/09 09:00 PM
06/02/09 09:00 PM
Posts: 4,587 St. John's Newfoundland
440newport
Budget build goes like this.Cast 72-78 440 pistons .030-040-060 over.About -.020 deck height.New rod bolts/resize.Balance to taste.If you use the steel 383 crank rebalance is mandatory.Low end torque?, go with the 60302-3 Lunati Voodoo.Dual plane not single plane intake.I prefer 915's to 906's and either to the 516's.If you prefer the 516 use the 1.74 exh valve not 1.81.2.14 int valve is fine in any of the heads.
I figured the compression distance of 440 pistons would be too much, but the federal-mogul P424NP has a CD of 1.912 vs the KB240's of 1.908. So not only is it slightly taller but the big advantage is it doesn't have that huge 5cc trough the KB piston does which I don't think you need for valve clearance anyways unless your running a huge cam? I guess the only thing is you have to have the block bored out to 40 or 60 over 440 size which is no big deal.
