tranny lines? #331815
05/28/09 07:30 PM
05/28/09 07:30 PM
GoDartGo Offline OP
GoDartGo  Offline OP
I'm running new transmission lines to the cooler up front. I have solid motor mounts and the lines are going along the frame rail.
Do I run a short rubber hose between the hard lines on the frame and tranny?
Or do I hard plumb it all the way?
Re: tranny lines? [Re: GoDartGo] #331816
05/28/09 08:20 PM
05/28/09 08:20 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Rubber connector hose should not be necessary.
Re: tranny lines? [Re: GoDartGo] #331817
05/28/09 08:23 PM
05/28/09 08:23 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
GDG ...I would run rubber. It makes it way EZier to plumb.
Re: tranny lines? [Re: dOrk !] #331818
05/28/09 08:53 PM
05/28/09 08:53 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The factory didn't even use rubber with rubber engine mounts. You have solid mounts, even less of a worry.
