8 3/4 Question #331683
05/28/09 03:02 PM
05/28/09 03:02 PM
When did Mopar start putting them in their cars?
Re: 8 3/4 Question [Re: ] #331684
05/28/09 03:20 PM
05/28/09 03:20 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
well according to this it looks like 1957 was the first ones
http://www.autohobbydigest.com/8_75.html
Re: 8 3/4 Question [Re: Mopar Ron] #331685
05/28/09 03:33 PM
05/28/09 03:33 PM
http://www.wwgauctions.com/sd09.cfm?page=4&pagend=10
So what would be under this 56 Chrysler wagon.
Page 4, all the way to the bottom, click on details and it will bring up a picture of the rear end. Click on the picture to enlarge.
Re: 8 3/4 Question [Re: ] #331686
05/28/09 03:46 PM
05/28/09 03:46 PM
Mopar Ron Offline
Mopar Ron  Offline
I have often thought that a lot of the early 50's rearends looked a lot like 8 3/4's
but i never liked the keyed axle and drum setup so I never looked into them any further Ron...
Re: 8 3/4 Question [Re: ] #331687
05/28/09 03:52 PM
05/28/09 03:52 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
IIRC most makes and brands had this style rear end or Drop out pumpkin. My father and I found out last year that my 53 Ford wagon had a spicer style rearend and not the dropout pumpkin style that his 53 2dr sedan had. My 49 Plymouth has a dropout pumpkin rear diff too! I thought sweet an 8 3/4 but was told it wasnt so I probably cant get gears for it
Re: 8 3/4 Question [Re: Mopar Ron] #331688
05/28/09 04:29 PM
05/28/09 04:29 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
From what I was able to tell when I was dealing with the rear in my 56, the "early" rear looks very similar to the 8¾ but is not as strong, has a different bolt pattern from pig to housing, and different axle flanges/bearings. After taking it apart, I can also tell you that it is much lighter duty.
That said, the E-body rear is near perfect width for the 56 Dodge/Plymouths, and I believe the 66-70 B-body rear is enough narrower that it'll allow for some extra tire. The perches would need to be moved inwards on either rear.
Hope that helps.
2 Demons...no, not my kids!
Re: 8 3/4 Question [Re: ] #331689
05/28/09 05:06 PM
05/28/09 05:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '56 and earlier rear end with a dropout is the 8 1/4", not to be confused with the later 8 1/4" that fit into an 8 3/4" housing or the later yet 8 1/4" non-dropout. It dates back to 1937 or so.
The pre-'57 8 1/4" carrier has 11 bolts attaching it to the housing, the 8 3/4" has 10.
