Choose a roller for my 500
#329842
05/26/09 10:20 PM
05/26/09 10:20 PM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
3500 lbs ebody, low deck 500, 10.5:1, Stage 6 heads MW size and ported, 950 carb, 4/5 speed, 3.91 gear. I use it on the street but want good performance at the 1/4. Solid roller cam only.
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
Re: Choose a roller for my 500
[Re: CH3NO2]
#329844
05/26/09 10:30 PM
05/26/09 10:30 PM
EV2CUDA
Oh Canada
Indy intake and TTI 2 inch, stepped I think. I was thinking about a comp 308R(575 lift roller)
[Re: EV2CUDA]
#329845
05/26/09 11:45 PM
05/26/09 11:45 PM
Posts: 3,078 Edmonton, Alberta, Canada
Dartman75
308 is a lot of duration for the street I think, even at that displacement. To be clear the 308R on COMPs site is a 650+ lift lobe, not the 575 you've mentioned.
The better your heads the less I'd try to cover it up with such a big CAM. You'd do better with a smaller CAM overall. I see the next step down in size is a 292R though and that might be a great street strip CAM, but might be leaving a small bit of potential on the table. But a 308R might kill enough bottom end, idle and other street characteristics that you might not end up liking it. COMP recommend 12+ compression with that CAM, where as they like 10.5 for the 292R. I and a number of guys have run the 286R cam in small blocks and like it very well. While a 292R might also be streetable, I'd have to give up a decent idle speed to pick up a small bump in top end RPM range. Since you're heads are going to flow way better than mine, you might find that you don't need as much CAM to extract a great amount from that many cubes.
It's all subjective. What you consider streetable isn't neccessarily what others will think is streetable. If you can better quantify what matters to you for idle speed, temps, vacuum, exhaust noise etc. Maybe someone can do a better job helping you sort that out.
Greg
[Re: EV2CUDA]
#329847
05/27/09 12:08 AM
05/27/09 12:08 AM
Dartman75
I see. You're looking at this one: http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=739&sb=1I was looking at this one: http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=744&sb=1The 292 I was referring to was actually the XR292R: http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=743&sb=1My mistake. The one you're looking at is just a less agressive ramp and probalby needs less springs etc. Personally I'd go for the more agressive ramp. You get more area under the lift curve, for the same or less seat to seat valve timing. The XR292R is spec'd slightly smaller, but lifts more and gets off the seat more quickly, having effectivley around the same overall area under the curve as the 3008R, and probalby make more power, and especially make more torque in the lower RPMS, idle better and pull more vacuum. Greg
[Re: Darryls-Demon]
#329849
05/27/09 06:10 AM
05/27/09 06:10 AM
Posts: 6,295 U.S.
moparniac
U.S.
I currently run the XR286R in my challenger car will go quicker as that is my first time out messing with the whole new setup.... so far my car et'd quicker shifting at 6000 instead of 6500 probably due to being a stroker.... Id say 6000 rpm is not beating on it at all remember those cam car specs are for a 440 and a stroke will bring the powerband down a few hundred rpms.... Indy EZ'z MW cnc ported 11.1 to 1 Straight 93 pump 2" TTI headers 3800lbs with driver ET street radials
Mopar Performance
[Re: EV2CUDA]
#329852
05/27/09 10:06 AM
05/27/09 10:06 AM
Posts: 31,052 Oregon
AndyF
The 292 street roller would be a good choice. I've run the 298 street roller and it makes great power in a 500 inch motor but the idle is pretty knarly. The 292 would tame down the idle a bit but still give you plenty of power. http://www.moparmusclemagazine.com/techa...lock/index.html
[Re: moparniac]
#329861
05/27/09 12:35 PM
05/27/09 12:35 PM
AndyF
XR298 dont come up in my camquest ???
If you read the article you'll understand what a XR298 is.
[Re: Dodgem]
#329862
05/27/09 02:06 PM
05/27/09 02:06 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Keep hitting post!
Was this supposed to be for a nitrous motor? Sure looks like a nitrous grind to me.
I cant understand the wide LSA that some people like to grind for a na motor, doesnt make sense to me?
I was told by Dwayne that the Comp Magnum rollers are easy on parts, but arent that great of HP builders.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: EV2CUDA]
#329863
05/27/09 02:08 PM
05/27/09 02:08 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
If you wait too long, Chris'll buy that cam too! My cousin has that in his 440 Charger..runs mint, street car. He just peeled off an 11.1 out of the garage with some tuning left...
[Re: EV2CUDA]
#329864
05/27/09 02:11 PM
05/27/09 02:11 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
doug herbert D6H
street drove for years with this cam easy on valve train 175 lbs on the seat easier on the wallet than most
WAXER
[Re: Von]
#329865
05/27/09 02:40 PM
05/27/09 02:40 PM
Dartman75
The Wider LSA flattens the torque curve, creates more top end power at expense of the pur peak power, improves vacuum and low RPM characteristics. Think of it as a more streetable version of the same CAM. I should note, my XR286R is a 112 LSA version that COMP ground for me per my order though Ou812 (aka brian). Brian was quite helpful in selecting that grind for me as well as input from other members that had been there done that.
[Re: Dartman75]
#329866
05/27/09 04:23 PM
05/27/09 04:23 PM
EV2CUDA
Oh Canada
Ya, I did buy it(575 lift) but its easy to change them. I like the one in the article so I will order that after I get the car running and do some testing with it first. BTW my engine was dynoed with a hydraulic roller 602HP/615TQ. That cam and it was dropping power after 6000rpm.
[Re: Von]
#329867
05/27/09 05:08 PM
05/27/09 05:08 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Keep hitting post!
Well it was a big NOS cam that I ground smaller but tried the 114 for throttle responce and low end. (no not mine I'll never use NOS)seem to work good pulled good out the end. great throttlle responce and idle reground another big NOS cam down to try now this one is 272/282 .650/.670 lift on a 110 lobe center. .696/,715 lift with my 1.6's. lots of used NOS stuff as we know NOS motors rest in pieces!!!! trying another
[Re: Dodgem]
#329868
05/27/09 05:32 PM
05/27/09 05:32 PM
Posts: 6,295 U.S.
moparniac
U.S.
whats is a ideal nitrous lsa 110 /112/114 ?
Mopar Performance
[Re: EV2CUDA]
#329870
05/27/09 06:34 PM
05/27/09 06:34 PM
RemCharger
Sk. Canada
Was that at Bruces's? They always seem to show that the power is dropping before it really does in the car.... Bens 440 seems to keep pulling..,He's still shifting up past what the dyno said...
[Re: AndyF]
#329871
05/27/09 08:40 PM
05/27/09 08:40 PM
Posts: 69 racine,wi
70gtx1
racine,wi
I just installed the 298r that Andy is speaking of in my 12.1 indy 440-1 headed 451. I just got the car up and running a week ago. Personnaly, I think the car idles pretty well, starts up pretty easy and sounds great.
