383 oil pan removal #329561
05/26/09 04:57 PM
05/26/09 04:57 PM
St. Paul, Mn.
Jim_S Offline OP
Jim_S  Offline OP
St. Paul, Mn.
Hello, does the engine have to be jacked up to pull the oil pan on a 69 b-body 383 in order to clear the oil pick tube or can you just remove the drag link and wiggle the pan out? I need to replace the rear main seal...Thanks
69 Roadrunner 383 stock
Re: 383 oil pan removal [Re: Jim_S] #329562
05/26/09 05:17 PM
05/26/09 05:17 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Just drop the drag link and you'll be fine.
