Page 4 of 12 1 2 3 4 5 6 11 12
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32973
02/01/08 05:55 PM
02/01/08 05:55 PM
Germany, Northcoast
Buschi340 Offline OP
Germany, Northcoast
last week I asked a Toyota dealer on this. There are 3 yokes available. 2 for the 5speed, 1 for the Auto. All are similar or the same. They couldn't tell me the difference except in the p/n. I bought a used driveshaft last week and will receive it tomorrow. I can measure it if you want. Or post a pic.
Clair, a problem is that the Tranny won't pass the old transmission mounting. You have to modify it or cut it out and build a new one.
And in my eyes the input shaft is approx. 5mm too short. I will let the Bellhousing be machined (where the Tranny is mounted)...
I have test-fitted it but I don't have the pilot bearing yet.
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32974
02/04/08 04:42 PM
02/04/08 04:42 PM
Germany, Northcoast
Germany, Northcoast
here is another website about the R154 I just found:
manual r154
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32975
02/04/08 07:37 PM
02/04/08 07:37 PM
Germany, Northcoast
Germany, Northcoast
Here's a pic why I'm a bit concerned about the tranny cross member. I need apprx. 1" more space, thats the half of the member. I don't want to cut it out complete because of the stability of the chassis. On the pic you can see the driver side of the tail housing. The front of the tranny is on the left.
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32976
02/04/08 11:39 PM
02/04/08 11:39 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Yeah, I didn't think there was any way that fatty of a transmission was just going to sneak in to the car without a little torch work. I'm actually a little surprised that it's only an inch you need, and I bet you could easily recreate that much by putting it on the top side of the existing x-member and boxing it up. That's pretty much how I planned on doing things, and just building a new x-member around the trans once I got it where it needed to be for driveshaft angles. Speaking of, how did you handle that aspect of the swap? Did you build some sort of jig to recreate the driveshaft yoke location, or just measure from a few spots on the floor?
Nice to see someone making some progress for a change. I've got a couple details on another option I'll post up as soon as I get everything uploaded to my web pages. Takes photos to show what's going on...
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32977
02/05/08 04:48 PM
02/05/08 04:48 PM
Germany, Northcoast
Germany, Northcoast
I measured the yoke to floor. 7.5cm.
I hope that some notches in the torsionbar X-member will be good enought.
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32978
02/07/08 01:20 PM
02/07/08 01:20 PM
Germany, Northcoast
Germany, Northcoast
Clair,
whats your opion about shorten the Bell on the tranny side approx. 5mm to get the input shaft more into the pilot bearing? I think its better than make a custom bushing which comes more out of the bearing hole. Don't yo think?
about the x-member I don't even have a solution yet. I saw some pics in the Net from cars which have this member cutted out completly. Builded professionaly.... I don't think that this is that good. Maybe I open the tunnel and widen the member a bit. Welding is not a problem....
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32979
02/10/08 10:52 PM
02/10/08 10:52 PM
Spokane, WA
48Heap Offline
48Heap  Offline
Spokane, WA
Here's what my crossmember looks like so far.
I made sure the centerline of the motor was parallel to the centerline of the car and made a reasonable attempt to get the carb mounting area level to the car/ground.
Your car will probably differ as I have an adapter plate pushing the trans back (don't know how the depth of your bell compares to mine) and I am working on a very early A-Body.
15 Chrysler 200S 3.6
15 Challenger R/T 6M STP
74 Duster 360 -> original 4 speed car
a.k.a. DionR
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32980
02/11/08 09:07 AM
02/11/08 09:07 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Hey, Buschi,
Sorry for the late reply, I've been fighting computer problems lately and didn't see the new post on my favorites list...
I need to check my numbers again, but I don't remember thinking that I needed an extended pilot bushing. Even if I did, I don't think I'd worry too much about though. As long as the trans is reasonably well centered, the pilot should see very little if any loads. I'll see if I can find my calculations again. That'll take some work, as we recently converted our "office" in to a room for our second kiddo that's arriving in May. I need to find all my stuff again...
Dion,
That is one battleship of a trans X-member! Looks great!
Clair
Re: 340sb with 5 speed conversion? [Re: 48Heap] #32981
02/11/08 04:54 PM
02/11/08 04:54 PM
Germany, Northcoast
Germany, Northcoast
Dion, thats a really strong one.
Clair, I made some pics as well. The inputshaft is just 10mm into the bushing/bearing. The first 5mm of the shaft has a chamfer (correct word?) so no contact here.
At all, for me is the point of no return reached...
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32982
02/11/08 04:55 PM
02/11/08 04:55 PM
Germany, Northcoast
Germany, Northcoast
next:
no clutch and pilot at this point...
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32983
02/12/08 12:54 AM
02/12/08 12:54 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
(still haven't found my notes...)
Seems like you could have a pilot bearing sleeve made up like the Mopar unit, but with a nose on it to support the OEM Toyota roller bearing. Ought to be easy work for any machine shop, especially if you have the Mopar bearing/sleeve to use as a go-by.
I guess you could mill the bellhousing as long as there is sufficient material there to support the loads after the job. I'm not a materials guy, so I don't know what the possibilities of that option really are.
Sure looks like you're making some good progress, though. I need to get some more info on my swap in the near future. The last few months have been nothing but parts chasing...
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32984
02/12/08 10:07 AM
02/12/08 10:07 AM
Germany, Northcoast
Germany, Northcoast
I already bought the Mopar Bearing at local chrysler dealer. Thanks god that I had the p/n's, they wouldn't find anything...
I thought I buy it for reference and build a new and longer one with a bearing which fits the Toyota input shaft.
I think machining the bell 2-3mm on both sides wouldn't hurt the stability.
Clair, if you are still chaising - pls chase the speedo cable for me...
Is it possible to install a centerforce dual friction? Or is Centerforce2 good enought (theoretically).
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32985
05/13/08 05:46 PM
05/13/08 05:46 PM
Germany, Northcoast
Germany, Northcoast
2 pics from my process. Built a new torsion bar x-member. Took the old, cut out and in peaces, wided, welded in and boxed....
(a lot more than expected)
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32986
05/13/08 05:47 PM
05/13/08 05:47 PM
Germany, Northcoast
Germany, Northcoast
2nd pic
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32987
05/13/08 05:50 PM
05/13/08 05:50 PM
Germany, Northcoast
Germany, Northcoast
thats how the tunnel looks now with new metal covered...
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32988
05/13/08 05:54 PM
05/13/08 05:54 PM
Germany, Northcoast
Germany, Northcoast
now I'm at the stage 48heap already did. Connecting the Supra tranny mount with the original transmission x - member. Or going a different way? I'm not sure, need advice....
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32989
05/13/08 06:03 PM
05/13/08 06:03 PM
Germany, Northcoast
Germany, Northcoast
Clair,
a question about the throwout bearing. I have an old one which I received with the Bell housing and clutch parts from the Dakota. I put it on the input shaft and recognized a little side play. About 1-2mm. Is it ok or too much? It looks a little loose to me...
Ok, another one. Can I use the original Dakota Bearing with a Centerforce Dual Friction Pressure Plate? I got one from a friend...
BTW, my propellershaft is 5cm (2") too short now...
Re: 340sb with 5 speed conversion? [Re: Buschi340] #32990
05/13/08 10:18 PM
05/13/08 10:18 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Clair,
Wow, Buschi, you're making great progress! I've really got to get back on the ball out in the garage, but it'll probably have to wait a bit longer. Our 2nd kiddo arrived a couple weeks early (April 21), so things have been a little crazy around here lately... I have done a couple little things, so I'll add a second post to keep them separate from this.
Throwout bearing. What bearing retainer are you using - the Toyota or Dakota? For the Dak TOB to work, you need the Dak bearing retainer. The Toyota TOB is a totally different design as I'm sure you know, so I don't think it would be easy to adapt. However, the Dak throwout lever is pretty simple, so MAYBE it could be adapted without much effort. If you don't have the Dak bearing retainer, let me know as I have to get one also - the parts trans I have has a crack in the retainer and I'd rather not risk using it.
Clutch. The stock Dakota clutch is the diaphragm type, so I don't know why you couldn't use the CFDF pressure plate. Does CF make a 10.5" clutch with the Toyota spline count? I think the truck part may be something like 10-3/8" DIA, which would be close enough for me, I think.
Driveshaft. I'm surprised that the driveshaft needs that much changing. A 904 and 833 are very close to the same length, and I really felt that the Toyota and 833 were very close to the same as well. I guess that means I shouldn't get a new driveshaft now and hope that it'll fit the Toyota as well...
Thanks for the update, I was going to email you today just to see how things were coming along. Strange.
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32991
05/13/08 11:29 PM
05/13/08 11:29 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Minimal progress, but still some.
For a while, I've been tinkering with some Jeep Liberty parts to adapt the Toyota R-154 transmission rather than the Dakota parts (bellhousing, starter, flywheel, etc) because the Jeep Liberty parts are more compact. My thinking was that the smaller parts would be happier living with the TTI headers & such. The Libby bellhousing uses a 10.4?" clutch and a flywheel essentially the same size as the 130-tooth old-school flywheel, but it appears to have 131teeth. AND, the bigger deal seems to be that the flywheel ring gear is located about 1/2" closer to the block than on the older engines. I found this out after bolting up my old 130-tooth FW and noting that the unique Liberty starter motor wouldn't reach the ring gear.
So, in a nutshell, I've got all these Liberty parts that will physically bolt the Toyota trans up to my 340, and I'm seeing what it's going to take to get a flywheel that makes the whole shebang work. If it's going to take a custom billet flywheel to do the job, the Liberty parts go on eBay and I'll pick up where I left off with the Dakota parts I have stashed. If I can get a FW with the right offset on the ring gear for a reasonable price, it'll be another option for folks who want to do this swap with mostly factory parts.
Clair
Re: 340sb with 5 speed conversion? [Re: Clair_Davis] #32992
05/14/08 06:25 AM
05/14/08 06:25 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
why not get a stock flywheel redrilled for the smaller clutch? basically all your adding is the 6 holes that bolt on the clutch if i'm understanding this correctly. if its too hard to drill, the flywheel can be EDM, this may not be a really cheap option but with minimal effort you could try it.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
