residual valve?
#328738
05/25/09 10:49 PM
05/25/09 10:49 PM
Posts: 553 Kentucky
clovis
Kentucky
I have a four wheel disc master cylinder I am thinking of trying to install on the Duster. I am running disc front/drum rear. Do I need a residual valve for the rear? I will mount in the stock location.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: residual valve?
[Re: bigtimeauto]
#328742
05/26/09 06:17 AM
05/26/09 06:17 AM
Posts: 553 Kentucky
clovis
Kentucky
>> In the mid-1970s, Chrysler eliminated the rear brake residual pressure valve from the master cylinder. Its function was to prevent any air from sneaking into the system via the rear wheel cylinder cups. In its place, Chrysler substituted "expanders" in the rear wheel cylinders. (Expanders are dish-shaped steel inserts that exert outward pressure on the cups.) If you should decide to use a master cylinder from a 1975-up car, be sure you have the expanders in your rear wheel cylinders. For at least 20 years they have been universal in all replacement wheel cylinders and rebuild kits.
This is from a Mopar Action tech article. My car is a '75. Does anyone have a picture of what these would look like (expander vs. nonexpander)?
Re: residual valve?
[Re: Cab_Burge]
#328744
05/27/09 06:31 AM
05/27/09 06:31 AM
Posts: 553 Kentucky
clovis
Kentucky
does the residual valve have to be mounted on the MC or can it be mounted anywhere in the line?
