cfm =horsepower #32855
12/24/06 10:19 AM
12/24/06 10:19 AM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
is there a rule of thumb ,that with ideal conditons. a certan amount of cfm added equals(x) amount of horsepower?
Re: cfm =horsepower [Re: mcat4321] #32856
12/24/06 10:23 AM
12/24/06 10:23 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The very general average is roughly 2hp per cfm. I say very general because I know of many engines that exceed that number by a bit, and a bunch that never reach it. It's hard to say because the bench results you are using are fairly subjective anyway. A good bench with "stingy" numbers may lead you to think you're making more power with less, and a generous bench may lead you beleive you are not making what you should.
Re: cfm =horsepower [Re: mcat4321] #32857
12/24/06 10:38 AM
12/24/06 10:38 AM
gregsdart Offline
gregsdart  Offline
On a motor with a well designed head, it is possible to reach 2.45 hp per cfm in a high hp buildup. 2.3 hp per cfm is more likely though, and pretty stout performance on a bigblock type build. My 528 makes about 880 hp, and has a headflow of 368 cfm at .700, the highest even number where the cam actually lifts the valve. There are so many variables involved that this number can't be taken too seriously, it is just a rough benchmark.
Re: cfm =horsepower [Re: mcat4321] #32858
12/24/06 10:50 AM
12/24/06 10:50 AM
Bigger is not always better( CFM & AIR SPEED )
Re: cfm =horsepower #32859
12/24/06 11:13 AM
12/24/06 11:13 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
These are great time wasters, and like most calculators, completely ambiguous. http://www.wallaceracing.com/calcafhp.php
Re: cfm =horsepower [Re: mcat4321] #32860
12/24/06 02:21 PM
12/24/06 02:21 PM
AndyF Offline
AndyF  Offline
I've found that on the type of motors I build (moderate perf motors) that 2 hp per cfm is a good rule of thumb. I just finished up some back to back dyno testing of intake manifolds and a 50 cfm increase in flow was good for 100 hp.
Re: cfm =horsepower [Re: AndyF] #32861
12/24/06 05:26 PM
12/24/06 05:26 PM
detroit area
moderncylinder Offline
detroit area
it gets hard to nail down cfm to hp relationships because it depends on what parts or circumstances you are talking about, 2hp/cfm is a general rule,, at 28".
on nhra stock eliminator cars its more of a gain because the heads flow so poorly, they are more restrictive to the displacement and accleration of the engine. they see more like 3-4hp per cfm.
also,, on an engine like a stroked small block or big block,, a 20 cfm gain will result in more of a power gain than on a std stroked or smaller engine due to the head being more restrictive to the larger engine.
jeff
Re: cfm =horsepower [Re: mcat4321] #32862
12/24/06 05:35 PM
12/24/06 05:35 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
I've seen as much as 2.52hp per cfm, that was on a 362" Super Stock motor, the Layer heads flowed 240, motor made 605hp.
Re: cfm =horsepower [Re: moderncylinder] #32863
12/24/06 05:39 PM
12/24/06 05:39 PM
yep, what they said. Its an ez formula and will get you very close.
Re: cfm =horsepower [Re: mcat4321] #32864
12/24/06 07:35 PM
12/24/06 07:35 PM
alabama
572daytona Offline
572daytona  Offline
alabama
Try this DUSTIN,mildly built,.257*cfm*8=hp all out,maxed built .300*cfm*8=hp, just decide what numbers you like best,its all a est till you get on a dyno or track test it all anyway.
Re: cfm =horsepower [Re: AndyF] #32865
12/24/06 10:05 PM
12/24/06 10:05 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
[quoteI've found that on the type of motors I build (moderate perf motors) that 2 hp per cfm is a good rule of thumb.
This was real close to what my engine made.Dwayne flowed my SR`s as they came from MM they came in at 309cfm with a std port opening. When it the dyno the result was 617hp.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: cfm =horsepower [Re: moderncylinder] #32866
12/25/06 02:10 PM
12/25/06 02:10 PM
My 9.25 to 1 comp. ratio 512 stroker 400 block motor made 612 hp at 5000 rpm on pump gas with a set of ported "906" that flowed 266 cfm at .600 at 28 inches.That is 2.3 hp per cfm, I was very happy with that. Your results may vary.
Re: cfm =horsepower [Re: Cab_Burge] #32867
12/25/06 04:20 PM
12/25/06 04:20 PM
What i don't understand is why SB guys think that they have to have heads that flow over 300cfm to get any power. The BB guys heads flow the same, if not worse....Whats the deal?
So lets say 300 at 600 with over 200 at 300 lift. that would be maybe 2hp per ci..now a big block will get alittle more out of that...but theres over 100ci there. Im just rambaling now....
Steve
