Page 3 of 3 1 2 3
Re: Exactly WHY is my car hard to start when warm? #328200
08/30/09 12:59 PM
08/30/09 12:59 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
Bump...
My '74 Fury 400 was a hot start and flooding nightmare when I went to a Thermoquad and Edelbrock intake. I swapped out the steel line for an insulated stainless mesh covered fuel line from the mechanical pump to the carb. Of course the composite body on the Thermoquad was designed to eliminate heat soak transfer to the fuel bowls but even with that, the big block generated so much heat that the only cure was to keep the fuel line cool. You not only cook the fuel in the bowls but the fuel gets cooked in the line from the pump to the carb. My only problem now is COLD starting! Always has been a bear... crank for 20 -30 seconds and then runs like cr*p for 4 minutes... IF it even starts.
how is your choke set up? On my 318, unless the choke is firmly shut, it'll just crank
Re: Exactly WHY is my car hard to start when warm? #328201
08/30/09 01:06 PM
08/30/09 01:06 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Another very easy thing to do to ease starting is to hold the gas pedal all the way to the floor when you atart the warm/hot engine. This helps clear teh engine of unburnt fuel just like unloading a flooded sitiation. Granted it isn't a cure but in all reality short of spending a lot of money there is none.
We went through alot of so called cures and fixes and in the end accomplished very little except spend money. The above helps, learn to live with it, we did.
Re: Exactly WHY is my car hard to start when warm? [Re: MoparforLife] #328202
08/30/09 01:14 PM
08/30/09 01:14 PM
Southaven, MS
BossRide Offline OP
BossRide  Offline OP
Southaven, MS
I have since cured my problem...
I suspect it was a combination of things. I replaced the original coil with a new one, added a heat shield, reset the timing and then fine-tuned the Holley with a vacuum gauge, and my starter had slowly been dying, getting slower and slower when cranking. I put a new one on and it spins over like crazy and fires right off.
I also had a charging issue after the motor mount broke and the alternator's positive post hit the inner fender. The regulator wouldn't allow more than 12 volts, so I replaced both of them.
Thanks to all who offered advice.
Re: Exactly WHY is my car hard to start when warm? [Re: BossRide] #328203
08/30/09 01:44 PM
08/30/09 01:44 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
mine does this too. but only if its hot out and it sits for 30 minutes or so. Then its hard to start and idles like crap until it clears up. theres gas on top of my center card and on the bottom of the aircleaner lid when this happens.
its definitely heat related. my carbs are boiling hot. so is the manifold and I have the heat crossover blocked and a valley tray. its heat soaking from the heads (aluminum conducts heat pretty well.
I cant use an insulator as my carbs seal to the hood (340 sixpack) so im interested in ways to fix this too. i can hear the gas gurgling in the bowls
Re: Exactly WHY is my car hard to start when warm? [Re: 1_WILD_RT] #328204
08/30/09 10:04 PM
08/30/09 10:04 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
Mine lights off instantly... I think the new fuel boils off due to engine heat.. In a modern fuel injected car where the fuel is injected & the fuel is always pressurized it's a non-issue but a carburator where the fuel sits on a hot engine....I've blocked the crossover & added a heat shield...
http://images.google.com/imgres?imgurl=h...sa%3DN%26um%3D1
This solved my buddy's starting problems so I tried one on my 440 air grabber. Had to remove it as there is not enough clearance.
I'm going to try blocking off the heat risers and add a thin aluminum spacer with 2 gaskets.
Re: Exactly WHY is my car hard to start when warm? [Re: BossRide] #328205
04/30/13 01:43 AM
04/30/13 01:43 AM
Newberg oregon
Daveo383fury Offline
Newberg oregon
I know these posts are a little old but it came up when I googled it. After reading the posts I went out and checked my 383 fury with edelbrock manifold and holley 4bbl. Started it up and let it run. Carb never got hot-maybe a little warm but not bad. Noticed immediately that the secondaries were leaking gas...drip drip drip. Gonna pull off the carb and check the body gaskets by the butterflies and change em out. Fortunately with holley you can adjust the floats from outside the carb. Turned the secondaries all the way down ran it again and no leak. Seems to have nothing to do with getting hot just a leaky carb.
Re: Exactly WHY is my car hard to start when warm? [Re: Daveo383fury] #328206
04/30/13 08:33 AM
04/30/13 08:33 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
My hot starting problems were solved by going to non-ethanol fuel which is becoming more available here in the Rochester NY area. It started at marinas as the ethanol was killing marine fuel systems and engines. I now use it in everything. Here is website:
http://pure-gas.org/
Re: Exactly WHY is my car hard to start when warm? [Re: 63stabamatic] #328207
04/30/13 09:01 AM
04/30/13 09:01 AM
Upper Midwest
Upper Midwest
Reason is that alcohol blends tent to have a much lower boiling point and will not take as much heat soak and will spill over the needle and seat causing a flooded condition. Starting warm/hot engines using blended fuels as you would a flooded engine by holding the pedal to the floor opening the throttle blades to allow more air to help clear the condition should help. Along with using a non blended fuel if possible.
Re: Exactly WHY is my car hard to start when warm? [Re: MoparforLife] #328208
04/30/13 07:12 PM
04/30/13 07:12 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
After reading the entire thread here...I admit
to having the same problem. My setup is just a
stock 360 engine with a Weiand dual plane manifold. A 3 year old Edelbrock #1406 600 cfm carb (junk IMO) and ceramic 1-5/8 headers. The car starts fine when cold....has NO spacer or shield on it....
when just warm, it very hard to re-start. This is
even in 50-60 degree weather as others posted.
I ordered (just about 2 hours before reading this thread) a 1/2" wood spacer and an aluminum heat shield kit from Jegs. I hope this helps out...and if not, I'll try the return line trick I read on here too.
Plymouth Makes It!
Re: Exactly WHY is my car hard to start when warm? [Re: RoadRunnerLuva] #328209
04/30/13 08:11 PM
04/30/13 08:11 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I read through this thread yesterday but didn't respond because the issue at hand was an old post, but here's my opinion.
While fuel percolation is an issue sometimes (and I have noticed with E-brocks in particular that I can hear the fuel boiling when I turn a hot car off, so listen for this) I think the majority of issues are cars with incorrectly set up chokes and incorrect timing.
How often do guys adjust their electric chokes?
In your case, with no spacer, I would start there. You don't need a half inch spacer or anything if you don't want one, but you can buy a thick carb flange gasket (like the factory ones) or stack a few of the thinner ones. However, if by warm you mean the car is 140 degrees you really shouldn't be having percolation issues, but a 195 degree engine with no spacer is going to have issues when turned off.
If it will re-fire within 2 minutes of being shut off but not after 10, then percolation is probably not your issue.
Re: Exactly WHY is my car hard to start when warm? [Re: jbc426] #328210
05/02/13 11:05 PM
05/02/13 11:05 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
I like this idea ... Or you have a bad needle seat.
Or misadjusted float levels..
I had this problem and was also baffled until I spoke with Doug Dutra, the famous slant six guru. He explained what was happening:
When you shut off a warm engine, the heat from your engine's intake manifold is boiling the fuel in your float bowl and causing it to drip into the intake etc causing an excessively rich condition. This happens because the fuel percolation drops the float and allows more fuel from the still presurized fuel line, between the fuel pump and the needle and seat to flow more fuel into the carb to bring the float level back to normal. This continues until the pressure in the fuel line between the fuel pump and the needle and seat goes to zero. In the mean while, a significant amount of fuel has now percolated out of the carb AND the pressurized fuel line between the fuel pump and the carb (until the presure is released by the process). Quite a bit of gas ends up in the intake every time you shut off a hot motor.
This is how you fix it:
#1 Use two gaskets and a sheet of aluminum to isolate the carb from the intake manifold. This will likely require longer carb studs. Be sure to check for hood clearance. (this helped a lot, but did not eliminate the problem completely)
#2 Install a fuel return line from a 3-nipple fuel filter, which is available from any autoparts store between the fuel pump and the carb, and the fuel tank. The third nipple on the 3-nipple fuel filters has a metered orifice to limit the amount of fuel it flows. I had to install a return line and a 2 fitting fuel sending unit on my 68 slant six car to complete this installation. The car had an original 5/16 fuel line, so I added a 3/8ths line as the main fuel line and used the 5/16ths line as the return. I bought a dual fitting fuel sending unit for less than $50 off ebay, ran the lines, installed the 3-nipple filter. I never had a hot start problem again.
Re: Exactly WHY is my car hard to start when warm? [Re: sogtx] #328211
05/02/13 11:19 PM
05/02/13 11:19 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Back in the early '90s I had a '66 Valiant, I had installed the super6 2bb intake setup on.
I did something similar, only not running a return line, I just T'd the hose from the 3rd nipple into the fuel line BEFORE the fuel pump.
My reasoning was that there was no pressure there, so anything bled off at the filter was just bled off.
So, was it just my imagination that made me think it solved my heat soak problem?
It takes gasoline to interest me.
Re: Exactly WHY is my car hard to start when warm? [Re: VL21] #328212
05/03/13 06:16 PM
05/03/13 06:16 PM
Land 'O Lakes
Land 'O Lakes
bump
Plymouth Makes It!
Re: Exactly WHY is my car hard to start when warm? [Re: cataclysm80] #328213
05/03/13 07:34 PM
05/03/13 07:34 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
This might make you feel better.
Mine has gotten to the point that it won't even start when warm. Nearly had it towed last week when I shut it down to fill up with gas. By the time the tow truck arrived it started and I was able to drive home. Fires up great cold, runs great, but if I turn it off and try to restart hot I can just crank away till the battery is nearly dead.
My original 1938 ford flathead does that same thing. I've been told it's caused by a bad coil that fails when it gets hot.
Check your spark next time it happens.
Tav
i had the same problem with my hemi. i have a electric fuel pump with a MSD ignition system. it used to start instantly hot or cold. then i started to have hot start problems that got worse over time. i replaced the coil without any improvement. i changed the distributor and the problems went away. a friend did some voltage test to the pick up coil and found that the pick up coil changed resistance when i warmed up.
perception is 90% of reality
Re: Exactly WHY is my car hard to start when warm? [Re: BossRide] #328214
05/04/13 02:09 PM
05/04/13 02:09 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The problems could be electrical of fuel related.
Electrical - make sure you have good battery cables and the negative is connected to the block and the body with clean connections. If using a stock ECU ignition box, run a ground wire from the ignition box to the engine (prevents ground loop issues in sensing the magnitic pickup pulse.)
Fuel - The real issue here is the fuel sold today vaporizes much easier than fuel sold in the 1970's. Blocking off the intake manifold heat crossover, and running a vapor return line helps prevent vapor lock and boiling the fuel in the carb.
Re: Exactly WHY is my car hard to start when warm? [Re: 451Mopar] #328215
05/04/13 06:22 PM
05/04/13 06:22 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
In my wagon I hooked up the three nipple filter and ran a line back to the tank. Starts faster than a late model when hot....
old video, but, still starts the same.......
John
Re: Exactly WHY is my car hard to start when warm? [Re: 63stabamatic] #328216
05/04/13 06:36 PM
05/04/13 06:36 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
yep mine went away just by doing the non eth fuel.. we have a few stations around here that sell it..headed there in a few minutes actually!
Re: Exactly WHY is my car hard to start when warm? [Re: BossRide] #328217
05/04/13 07:04 PM
05/04/13 07:04 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Hot starts after 15 minute or longer I always had best result with gas pedal partial or to the floor. Today's crappy gas is so wonderful!!
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Page 3 of 3 1 2 3
