Best Transmission Yoke & U joint? #327931
05/25/09 08:21 AM
05/25/09 08:21 AM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
Who sells the best transmission yoke and u joint?
i see mark williams is the most expensive but i see S & W has the only billet steel one of $182.00
Strange has one that looks pretty good as well.
Strange seems to sell the nongreaseable heavy 1350 u joint non drilled one.
i need one to hold up to 810 ft. lbs of torque.
also i need to get some forward limiters on the motor and trans.
Re: Best Transmission Yoke & U joint? [Re: JACKSON] #327932
05/25/09 10:34 AM
05/25/09 10:34 AM
an8sec70cuda Offline
Mark Williams billet steel 1350 series slip yoke here. Been in my car for about 6 years w/ no trouble. Just using Spicer 1350 joints from my local driveshaft builder.
As far as a limiter, I bought the Comp Engineering kit and fab'd it up myself. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best Transmission Yoke & U joint? [Re: an8sec70cuda] #327933
05/25/09 12:53 PM
05/25/09 12:53 PM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
thanks chip, thats the one i was going to buy, i saw S & W billet steel also, not sure about the differences between the 2.
