Cal-Tracs and transbrakes...what's your setup?
#327001
05/24/09 11:59 AM
05/24/09 11:59 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
For those of you running Cal-Trac rear suspension and a transbrake, what's your setup consist of?
Meaning... ET and MPH for the combo? What tires and tire pressure? What rear shocks? Preload on the Cal-Trac bars? What RPM do you leave at?
I tried the 'brake for the first time last night and it absolutely blew the tires off. Tried a few different setups and made little progress. Hooked great footbraking it. I am running Drag Radials, but curious to see what works for yall. Thanks, CHIP
Re: Cal-Tracs and transbrakes...what's your setup?
[Re: Bob_Coomer]
#327003
05/24/09 02:44 PM
05/24/09 02:44 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
My info may not help you as you have WAY more motor but 17 psi 12 inch wheels 315/60, 1/4 turn preload on drivers' side snug on passenger side,rancho single adjustable on 7,cal trac 90/10's on front. Leave at 3400 rpm on a 4200 convertor.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: 67HEMI]
#327004
05/24/09 08:20 PM
05/24/09 08:20 PM
an8sec70cuda
Bob...I think you're right,it may take a while but I want to make it work. It feels like a monster when I let go of the button, but as soon as the wheels get in the air it slams them back down and fries the tires.
67wedge...thanks for the info. I tried a setup close to yours last night and it didn't work for me, but I'm gonna keep at it.
Anyone else? CHIP
[Re: 67HEMI]
#327005
05/25/09 07:19 AM
05/25/09 07:19 AM
Posts: 2,175 Duloc
The Shadow
Duloc
Isn't the preload to go to the passenger side with your weight in the driver seat?
I find this thread interesting because we have similar set ups. I have yet to run the car with the new motor but it would be cool if you can get it to work. Please be sure to share your info if you can
[Re: QWK_ENUF]
#327007
05/25/09 10:41 AM
05/25/09 10:41 AM
an8sec70cuda
So are me and 67wedge the only 2 here running Cal-Tracs and transbrakes? CHIP
[Re: Lil Wedge]
#327009
05/25/09 02:12 PM
05/25/09 02:12 PM
an8sec70cuda
I have 6" of travel up front and the front end is loose.
I've tried no preload, 1/4 turn preload, and 1 turn preload. I've tried 19.5 psi and 15 psi in the tires, not much difference. Made a big change just to see what would happen.
Hooks the best footbraking w/ 19.5 psi and no preload. 1/4 turn preload works well footbraking too. 9 way ranchos have been set on 9 for the past 3 years since that's where it hooked the best footbraking. Have not tried a different setting on them yet with the transbrake. CHIP
[Re: Lil Wedge]
#327011
05/25/09 02:35 PM
05/25/09 02:35 PM
an8sec70cuda
LilWedge...I have some "custom" lakewood 90/10s. I drilled and drained them, then replaced the fluid with marvel mystery oil. They're pretty loose. Work great on motor (wheelies as high as your picture footbraking), but obviously lacking on the transbrake. I've been wanting to put a pair of Calvert 90/10s on the front but havn't gotten around to it. I watched the video. As soon as I release the button , the front tires are in the air (only 2-3") for a split second and then touch back down when the rears go up in smoke. So slow up the front end rise? CHIP
[Re: Lil Wedge]
#327014
05/25/09 06:00 PM
05/25/09 06:00 PM
Posts: 316 Ohio
Lil Wedge
Ohio
[Re: Lil Wedge]
#327015
05/25/09 06:00 PM
05/25/09 06:00 PM
Posts: 2,152 Fancy Farm Ky
wyoming
Fancy Farm Ky
I think you need to slowdown the front end rise, and more travel would help, I run the Koni shocks set to the middle, think that is supposed to be 70/30, I have no front end limiters, right at 6 1/2 travel, if it just jerks the fronts and spins you have to slow the front down, or figure out a way to give it more travel, I had to rig some shock extensions with the Koni's to get the 6 1/2, now as far as those DOT rears, I have no expewrience with those, all my runs on slicks, so not sure if my advice is the best or not. If possible weigh out all four corners, you in the car, get rears as close to same as possible, run about a dime gap on the Caltracs, should be the working spot, if not increase preload 1/4 turn at a time, I run mine in bottom, but it pretty muchs works in either hole, get those rear wheel weights close, it'd help to if you bought a set of real drag tires, IMHO
[Re: wyoming]
#327016
05/25/09 06:10 PM
05/25/09 06:10 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Maybe I missed it, but how much front end travel do you have? If it hooks initially, and then unloads the tires when the front wheels come up you might want to lower the front end. Sounds counter intuitive to take weight off the rear by lowering the front, but it will give it more total front end travel. It might be enough run at the front suspension that when it pulls the front wheels up, it will just keep going up and not unload the rear suspension. My
[Re: wyoming]
#327020
05/25/09 08:31 PM
05/25/09 08:31 PM
an8sec70cuda
Lilwedge...Thanks for the info! Wyoming...I think you're right about the slowing the frontend rise. It took some doing to get the 6" of travel I have now. Removed the UCA bumpstops, shock extensions, and tall front tires so I could lower the front down as much as possible. I went to these DOT radials b/c I was having trouble getting to hook at all w/ bias ply tires. The tech guys at M/T told me to get these and I was pleasantly surprised w/ low 1.3 sixty foots. They hook better than any slick I've ever had on the car. I've seen fast drag radial cars with transbrakes so I know it can work, just need to know what direction to go w/ the suspension tuning. I hope I don't need to go back to a bias tire to get it to hook on the transbrake. Dizuster...6" of travel. I can't really get the front end any lower. The oil pan is barely 3" above the ground now. I put 28" tall tires on it a few years back so I could lower it more to gain travel. WedgeOmatic...Thanks for the vid links. 67wedge...If you lived nearby I wouldn't mind seeing what it'd run in your car! It's not porpoising, I fought that issue a few years ago. I'll be giving Calvert Racing a call tomorrow and see what they recommend. CHIP
