Why not get a shroud and clutch fan?
Tom
At least a clutch fan, but a shroud may be needed depending on any heating issues.
I run a summit rad and northern shroud with a clutch fan, had to put a 180 stat in it since it wouldn't get over 150 cruising down the road with the 160 stat.
I had one originally and it was way to close to the radiator. It would have chewed it up in no time.
