Re: How do I know if my 60' times are correct for my Car [Re: 71440dart] #324729
05/21/09 11:16 PM
05/21/09 11:16 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
Mine is dead on 10.22/1.42. 3400# with MT street tires. Calculator says 1.42.....Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: How do I know if my 60' times are correct for my Car [Re: Wicked49670dart] #324730
05/21/09 11:38 PM
05/21/09 11:38 PM
I have seen a sixty foot change from 1:43 to 1:52 from a low(180 ft above sea level) altitude track to a higher altitude(2500 FT ASL) with no changes to the car Traction ,parts, HP and torque help determine the sixty foot times
Re: How do I know if my 60' times are correct for my Car [Re: Cab_Burge] #324731
05/22/09 01:40 AM
05/22/09 01:40 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
But Cab, the ET changed as well, right? The calculator determines the 60' based on the ET, so altitude wouldn't be part of that equation. It already affected the ET, so the slower 60' would follow.
Re: How do I know if my 60' times are correct for my Car [Re: G_bob] #324732
05/22/09 02:21 AM
05/22/09 02:21 AM
The ET does change as well, your right. I don't use calculators to determine my results, just the time slips LOL, test, test and test some more to get results, good or bad
Re: How do I know if my 60' times are correct for my Car [Re: Mopar_Mike] #324733
05/22/09 08:00 AM
05/22/09 08:00 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
The calculator says I should have a 1.79 sixty foot, it goes 1.81 so it's pretty close. With worn out drag radials, SS springs, and truck shocks, I guess that's not too bad. My best ET is 12.91.
Re: How do I know if my 60' times are correct for my Car [Re: Dodgem] #324734
05/22/09 08:23 AM
05/22/09 08:23 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I could be wrong but the too big 60 foot killers are 1 tire spin and 2 driving through the converter.
This means the converter is a little tight for the cam and where it is degreed and the car goes aways before it hits it's power band will act like a sudden increase in power like you just gave it more throttle.
And add that some vacuum actuated 4 barrels come on what to late with improper spring tuning and sometimes diaphram leaks and other problems.
In other words your leaving before the converter flashes?
RS23L7 4-Speed
