Re: needing valve spring set up with 200# - SB
[Re: goldmember]
#323287
05/20/09 12:27 AM
05/20/09 12:27 AM
Posts: 292 Keizer, Oregon
Dadrules
Keizer, Oregon
this car hasn't seen the street yet. it's been a 5 year project and my goal (kind of a bucket list thing - i've had 3 brushes with cancer and am cancer free for now) is to race it this summer - I'm new at this even tho I was born before 1950.
here's more specific info - 318 bored .030 over, block is decked - pistons are .00 KB167 hypereutectics - 9.7:1 compression, rotating assembly balanced, cam is a mopar performance P4452759 .430"/.450" lift, 260/268 duration cam,Indy 1.6:1 roller rockers, 302 heads with 1.88 intake and 1.60 exhaust, well ported, bowl blended short turn radius cleaned up, Dougs 450 headers,quickfuel technology 680 cfm carb with vacuum secondaries.
[Re: Dadrules]
#323289
05/20/09 07:20 AM
05/20/09 07:20 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
The camshaft, are you giving the numbers factoring in the 1.6 ratio rockers or is that the numbers with the stock 1.5's?
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
[Re: StandOnIt]
#323290
05/20/09 08:04 AM
05/20/09 08:04 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
those are 1.5 ratio lift #'s IIRC...with 1.6's it'll be .459/.480
I agree, sell the lifters, just pick up a set of normal lifters and be done with it.
what's you're installed height? to get 200 lbs seat pressure, you'll probably need double or triple springs.
for the $$ you spent on the schubecks you coulda had a nice retrofit roller cam and roller lifters. or you coulda started with an '85 up block and used OEM roller lifters....
one other question; did schubeck make hydraulic lifters? I thought they only made solids....I wouldn't run a solid lifter on a hydraulic cam.
