are BB #516 good for performance? #3229955
04/29/24 12:27 PM
04/29/24 12:27 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
So I popped a pair of big block #516 heads for sale on another forum and checking my email this morning, I found I had half dozen guys have reached out to buy them. I know the close chamber helped bring up compression, but is there anything else about these heads that makes them desirable?
Re: are BB #516 good for performance? [Re: migsBIG] #3229957
04/29/24 12:29 PM
04/29/24 12:29 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The closed chamber is the big selling point , especially since they can be had cheaper than 915's. they need the exh valve upgraded to at least 1.74 and porting to come alive .
Re: are BB #516 good for performance? [Re: JohnRR] #3229959
04/29/24 12:32 PM
04/29/24 12:32 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
thanks John. Yeah that tiny ex valve looks restrictive.
Re: are BB #516 good for performance? [Re: migsBIG] #3229981
04/29/24 02:03 PM
04/29/24 02:03 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: are BB #516 good for performance? [Re: migsBIG] #3229982
04/29/24 02:10 PM
04/29/24 02:10 PM
AndyF Offline
AndyF  Offline
There is nothing desirable about them other than the cheap price.
If you can sell them great. I've thrown away a lot of those heads in the past since there wasn't a market for them. I used to take them to swap meets and try to sell them for $100 a pair with no takers. Lowered my price to $50 a pair and still not takers so they all went in to the recycle place.
Re: are BB #516 good for performance? [Re: AndyF] #3230008
04/29/24 03:28 PM
04/29/24 03:28 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I went 10.40’s with them back in the late 1970’s with a set in my 69 dart. I wouldn’t scrap them.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: are BB #516 good for performance? [Re: migsBIG] #3230011
04/29/24 03:38 PM
04/29/24 03:38 PM
Cab_Burge Online work
Cab_Burge  Online Work
if you want good improvements from swapping heads step up to a cheap set of aftermarket aluminum heads with the bigger, better flowing valves and ports wrench twocents scope up
Re: are BB #516 good for performance? [Re: migsBIG] #3230129
04/30/24 07:59 AM
04/30/24 07:59 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Some guys on a budget want them.
Some regions of the U.S. are pretty lean on old cast iron cylinder head cores.
I ran a set on my 69 RR, added the 1.74 exh valve, bowl ported them with the MP templates, gained 2-3 mph through the traps.
It ran low 13's @ 105 mph. Just a warmish 383 B-motor, 833, 284/484, TM6, 750 AFB, 4.30:1, 10" slicks, 1.99 60'.
Re: are BB #516 good for performance? [Re: migsBIG] #3230142
04/30/24 09:01 AM
04/30/24 09:01 AM
an8sec70cuda Offline
If you're on a budget, they're great in my opinion. Big exhaust valve, a little porting, and they will run decent numbers. Not aluminum head numbers, but not aluminum head $$$$ either.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: are BB #516 good for performance? [Re: Brad_Haak] #3230150
04/30/24 09:49 AM
04/30/24 09:49 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Originally Posted by Brad_Haak
For me to consider them, there would be two key questions to answer first:
1. What do I have to spend to make them usable in the first place (e.g., valves, seat & guide work, milling)?
2. If I want more than as-cast performance, how much do I have to pay to have someone do enough porting to reach my goals (assuming I can't do it myself)?
I wouldn't want to put much money into 60 year-old castings in this day and age...
Re: are BB #516 good for performance? [Re: Brad_Haak] #3230163
04/30/24 10:15 AM
04/30/24 10:15 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I look at it as……. How much less than a set of aluminum heads would the “all in” price for any old iron heads have to be for you to go down that path?
And……. Can that be realistically done(price wise) in your area?
Machine shop labor prices keep going up……… but so have new aluminum heads.
Re: are BB #516 good for performance? [Re: fast68plymouth] #3230392
05/01/24 06:02 AM
05/01/24 06:02 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
By the time you put hard seats in, new 1.74 valves, port them, guides and a valve job you could just as well buy a new set of aluminum heads. Having said that years ago I did a set for myself, plus I shaved them .060. I ran 12.19@106 in my old truck with them. I put a lot of work into them but they guy worked real cheap (me).
Re: are BB #516 good for performance? [Re: pittsburghracer] #3230445
05/01/24 11:27 AM
05/01/24 11:27 AM
AndyF Offline
AndyF  Offline
Yeah, 50 years ago they weren't a bad choice
Re: are BB #516 good for performance? [Re: AndyF] #3230450
05/01/24 11:44 AM
05/01/24 11:44 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
My days of sitting in a cold garage learning to port on a set of OEM iron heads are decades behind me
Re: are BB #516 good for performance? [Re: Brad_Haak] #3230655
05/02/24 01:29 PM
05/02/24 01:29 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
My expected combo (65 426 wedge) is the 516, 452 or Eddy head with 1.60 ex valve. Cam is limited to .431 lift and any duration no porting but any valve job. I’m thinking of running 40 degree or less seats (more flow in overlap with the low lift). What about nail head vs tulip valve shape? I have a few extra 516 heads to experiment on but still looking for the 67 small valve heads.
Re: are BB #516 good for performance? [Re: cudaman1969] #3230688
05/02/24 06:00 PM
05/02/24 06:00 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
30deg, & a nailhead valve, works great on a low lift setup
Re: are BB #516 good for performance? [Re: AndyF] #3230710
05/02/24 08:31 PM
05/02/24 08:31 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Ahhhhh one of many “boneyard performance” upgrades of our youth. Grabbing a set of those was akin to crawling under a van or truck and scoring some 3.9 or 4.1 gears.
Re: are BB #516 good for performance? [Re: J_BODY] #3230722
05/02/24 09:05 PM
05/02/24 09:05 PM
PA.
"Little"John
"Little"John
PA.
Some of these guys don’t understand the fun we had making this stuff go fast. Lol
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: are BB #516 good for performance? [Re: pittsburghracer] #3230732
05/02/24 09:44 PM
05/02/24 09:44 PM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
My scores were 915 casting.big or small exhaust valve
Re: are BB #516 good for performance? [Re: CSK] #3230741
05/02/24 10:49 PM
05/02/24 10:49 PM
fredericksburg,va
fredericksburg,va
