70 Back - B Body - Cars For Sale - 2nd Quarter
#3223928
03/31/24 11:24 AM
03/31/24 11:24 AM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
1969 Hemi Dodge Charger
[Re: moparts]
#3224126
03/31/24 09:46 PM
03/31/24 09:46 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Putting my 69 Charger up for sale. Please read the entire add before asking questions. Sorry about the pictures I am not much of a camera man but I will answer all questions. Message me here for any information or contact number. 1969 Hemi Charger. Not an original Hemi car. 528 Hemi. Runs on premium pump gas. Dynoed at 642 HP and 650 TQ. New MP Iron Block and heads. Stage 2 head porting. Indy roller rockers. New rocker shafts and stands. Custom push rods. New oil pump. New oil pan and sump screen. Comp Cam flat tappet hydraulic. Mopar performance single carb aluminum intake. Polished Indy aluminum valve covers with breathers. TTI ceramic coated headers TTI 3 inch h-pipe exhaust. Bungs welded in collectors for O-2 sensors. Pro Systems carburetor. Carter HP mechanical pump with fuel gauge. Mopar performance air cleaner. New fuel tank, sender, lines. Fuel gauge calibrated. Mancini ready to run distributor. MSD coil Moroso custom wires Custom serpentine belt drive. Aluminum water pump and housing. 125 Amp one wire alternator Mini starter. Cold case radiator and fans. Custom polished ss recovery bottle. All new radiator and heater hoses. Classic auto air system. Firm feel stage 2 gear box. New power steering pump and hoses. Complete front suspension rebuild all Moog parts. Offset upper control arm bushings for better caster adjustment. Firm feel solid tube tie rod adjusters. Original Hemi K-frame and engine brackets and mounts. K-Frame blasted and powder coated. All suspension parts blasted and powder coated. Firm Feel HD torsion bars New front shocks. Precision steel drive shaft 1350 joints. TKO 600 5 speed .64 OD. Complete 5 speed conversion kit from Keisler. Sachs clutch rated for 700 HP. Clutch and brake pedals, mount, braces all restored. All new pedals and pads. Strange Dana 60, Locker 3.73, gears.All new. Dr Differential Ford SVO rear disc brakes with park brake. Wilwood front discs. All new brake lines and hoses. New master cylinder and proportioning valve. Torque thrust 2 wheels. BFG tires New rear springs. New rear shocks. All new wiring front to rear. New AMD front and rear bumpers. All bumper brackets blasted and powder coated. All new tinted glass. All new cat whiskers. New vinyl top. All stainless trim professionally restored and polished. New remote control mirror. All new name plates/emblems. All new locks and keys. Restored fuel fill tube. All new vent hoses. New fuel fill cap and door with bezel. New trunk mat. Jack and hardware restored and powder coated. New upper and lower door panels. New carpet. New under carpet sound deaden-er pad. Custom carpeted floor mats with Charger lettering. New sill plates and extensions. New outer and inner door handles. All seat frames blasted and powder-coated. Rear seat professionally restored with new legendary covers. Front seats professionally restored with new legendary covers. New front headrests with all new hardware. All seat hinge covers and knobs are new. All new seat belts. All console plates and hardware is new. New shift boots. Factory AM-FM radio. New antenna. New front and rear speakers with fader. Factory cluster with tachometer professionally restored. Voltmeter conversion. New speedometer cable. Speedometer calibrated correctly within 2 mph by radar. Steering column restored. New turn signal switch. New wood grain wheel. Dash frame blasted and power coated. New dash pad. New A-pillars. New visors. New headliner with insulation. New back seat divider panel with sound deaden-er pad. New rear shelf with sound deaden-er pad. New inside rear window trim. New window cranks. New arm rests and chrome bezels. All internal door and window hardware restored. All new weatherstripping. All new hood, inner fender, core support seals. New hood mounted turn signals and wiring. Restored wiper motor. All wiper linkage restored, Bushings replaced. New washer bottle, pump, hoses nozzles. Grille professionally restored. Grille frame blasted and power-coated. All new grille trim and hardware. Electronic headlamp door openers. Headlights run off relays. Body completely striped, soda and other media to a bare shell. Fenders, doors, hood and trunk done the same. New American made factory quarters. Not from China. New trunk floor. New trunk extensions. New driver front floor pan. Rest was normal metal finish with zero rust. Welded in frame connectors. Added Hemi rear torque boxes,rear shackle and pinion floor reinforcements. Car was a Colorado car barn stored since 1990. Overall a very clean car. Originally a base model 383, automatic, 8 3/4 rear. Completely painted inside and out B5 Blue. Outside completely done base coat clear coat B5 Blue. Custom Matte black 528/HEMI Tail stripe. The underside is as clean as the outside. Front end computer aligned with print out. Have build sheet and fender tag. All body numbers match. 200 miles since completed. I am getting older and have lost interest, only reason for selling. 120,000.00 Car sold as is where is. No warranties expressed or implied. Clear title in my name. All funds must clear before the car moves. Inspections welcome. Will help load. No shipping on my end. Buyer needs to supply shipper.
Re: 70 Back - B Body - Cars For Sale - 2nd Quarter
[Re: moparts]
#3224347
04/01/24 05:49 PM
04/01/24 05:49 PM
Posts: 95 ny
quill
ny
1964 Plymouth Savoy. 2Dr Post 4 Speed Rolling Chassis. K Frame Redone with Polyurethane Bushings, Front Disc Brakes, New Brake Lines, including Hoses, New Shocks. Late Model Rear with 392 Sure Grip 11 inch Backing Plates, Shoes and Drums, New Gas Tank and Sending Unit, New 3/8″ Fuel Line. Interior was all Soundproofed including Doors. All Glass was removed, all Window Mechanisms were Cleaned and Reinstalled. Windshield and Rear Glass have New Gasket. Radio Delete New Engine Wiring Harness. $21,000 OBO South Carolina Title. Car located New Bern NC Email- jany63@optonline,net
1969 Sport Satellite Pro Street Project 25k obo
[Re: moparts]
#3227929
04/18/24 04:10 PM
04/18/24 04:10 PM
Posts: 9 Clarksville, TN
toast253
Clarksville, TN
Selling my 1969 Sport Satellite Pro Street Project. I have had this car since 1996 and it was my daily driver in High School but unfortunately, I do not have the funds or time to finish the project. I am getting out of the military soon and need to start downsizing. The car has been sitting for a while and does have some surface rust, but no metal pitting. I will try to list everything as best as I remember. I have a lot more pictures as well. The pictures are not great, but absolutely everything that was on the car when I was daily driving it is still there in the bins. The only thing I can think of that might be missing is a body wiring harness, belts, and some gaskets maybe. I do have the clean title in hand.
The body: Paint will need to be finished...jams, engine bay, and hood. Full Cage with swing outs. Cage is punched through the firewall, not welded to it Sub-framed Tubbed 4-Link suspension Trans Tunnel POR rust protectant on the underside DYNAMAT in the interior All metal work is complete, and all gaps and lines are perfect. All glass is included; however, it is original and kind of hazy. Battery re-location kit Fuel cell and fuel tank included depending on the direction you want to go. Original seats front and back in perfect condition as well as some Corbeau front seats that need some cleaning. Original steel hood and Fiberglass lift-off hood All original Gages, dash, trim, bezels, bumpers, lights, etc. included. New GTX grill and badging (perfect condition) included as I was going to make it a clone.
The Engine: Original numbers matching 383 can be included. 440 build - never been assembled, block will need to be tanked for clean-up - all machine works complete. Should spec out around 700 hp when built. Indy Heads Indy high rise single plane intake Eagle Crank COMP Cam COMP Roller rockers ARP Head Stud kit and all gaskets MDS 6AL Ignition TTI Ceramic coated headers All pulleys, pumps, alternators, plugs, ignition wires, etc. included. 727 Transmission – was rebuilt with a shift kit, but probably needs a clean up after sitting
Drivetrain: Dana 60 with Strange 4.56 Spool - Never used. Yukon Axles - Never used. Drag Star Wheels - tires were never used, however are dry-rotted. Good enough to get it home but not good enough to drive on. Flow master mufflers (don't remember if they are 20 or 30 series) Strange Coil Overs Wildwood full brake kit - Never installed.
This is all I can remember for now. I have a lot more pictures available that I can send if anyone is interested. Unfortunately, I am not able to deliver or help much loading due to a recent shoulder surgery. No Trades Please.
1967 Dodge Coronet 440 original paint
[Re: toast253]
#3230101
04/29/24 11:26 PM
04/29/24 11:26 PM
Posts: 209 MI
IROC78
MI
SOLD THANKS MOPARTS !
1968 CHARGER R/T 440 AUTO "XS29L8"
[Re: moparts]
#3230860
05/03/24 06:55 PM
05/03/24 06:55 PM
Posts: 551 ORANGE PARK,FL
gdmusclecar
ORANGE PARK,FL
68 DODGE CHARGER R/T 440 AUTO,REAL "XS29L8" CAR,THE ENGINE IS NOT THE ORIGINAL ENGINE,ITS A C440 67 440 ENGINE WE DID GET THE ENGINE TO CRANK,WE HAVE NOT CHECKED THE TRANSMISSION TO SEE IF ITS THE ORIGINAL TRANSMISSION OR NOT,THE INTERIOR IS COMPLETE,DASH,DOOR PANELS,HEADLINER IS VERY NICE,IT HAS THE ORIGINAL WRAPPERS ON THE REAR SEAT BELTS,DASH VIN,FENDER TAG, BUILDSHEET IS ALL THERE,THERE IS NO TITLE,THERE WAS NO OPTION TO CLICK ON FOR NO TITLE,IT WILL COME WITH A BILL OF SALE,A TITLE COMPANY CAN GET YOU A TITLE.THE WORST PART OF THE CAR IS IT WLL NEED MOST OF THE SHEET METAL REPLACED,THE FLOORS,TRUNK PAN,FRAME RAILS AND TORSION BAR CROSSMEMBER IS RUSTY,THIS IS A MAJOR PROJECT AND NO IT DOES NOT RUN AND DRIVE,AND THIS IS AN EXTREMELY RARE CAR.
$25,000
ORANGE PARK,FL.
EMAIL: GDMUSCLECARPARTS@YAHOO.COM
PH# 904-589-4645
68 DODGE CORONET R/T 440-4SPD CONVERTIBLE
[Re: moparts]
#3230865
05/03/24 07:12 PM
05/03/24 07:12 PM
gdmusclecar
ORANGE PARK,FL
68 Dodge Coronet R/T 440-4 Spd Convertible ***1 of 88 built***
68 Dodge Coronet R/T Convertible 440-4spd,3.54 Dana 60,date coded drivetrain rebuilt,new 15 x 7 magnum 500 wheels,new tires,new brakes,new convertible top,hydralic cylinders,lines,new interior,new chrome bumpers.Too much to list,factory blue car with black interior.
Orange Park,Fl.
Price $89,000
email:gdmusclecarparts@yahoo.com
ph# 904-589-4645
