Page 3 of 3 1 2 3
Re: Enclosed car trailersI [Re: Magnum] #3229214
04/25/24 09:10 PM
04/25/24 09:10 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
Originally Posted by Magnum
Once you decide on a trailer. You will have to consider upgrades.
I drove flatbed tow truck for 5 years. Secured the cars on the bed with chains, wheel straps through the rims and wheel straps. Holding the car by the frame is the worst thing you can do to a car. It feels solid but when that bed or trailer hits bumps it will bang into the chains and oval out holes. If the car dips on the suspension, all good. When it extends up, it will smash into the chains so hard dirt and rust will be sitting on the bed to prove what happened.
E tracks to secure all 4 tires is the best method. Have 3 fail and the car will still be there. This is how all the manufacturers tow the new cars.
Not all new cars, like the Vipers the frames were reinforced to chain them down, some other high-end cars are the same. Axle straps are still the safest and easiest to use besides straps through the wheels if it is possible to do that. Using wheel straps in an enclosed trailer is not always easy, especially for us old guys. I have never had an issue with axle straps over the rear axle and trough the lower control arms... twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: Enclosed car trailersI [Re: Rhinodart] #3229235
04/25/24 10:08 PM
04/25/24 10:08 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I have always wrapped around the rear axle and thru the K frame on the front.
I am considering getting a pair of the brackets that bolt on with the rear axle U bolts for the rear though.
Re: Enclosed car trailersI [Re: gtx6970] #3229241
04/25/24 11:50 PM
04/25/24 11:50 PM
Rhinotruck
Rhinotruck
[quote=Magnum]Once you decide on a trailer. You will have to consider upgrades.
Those are nice, I wish everyone had them! When I worked for Mr. Norms Garage all our custom builds had oval rings welded on front and rear, made my job much easier, especially when I had the 4 car stacker!
A-Body's RULE!
Re: Enclosed car trailersI [Re: Rhinodart] #3231069
05/04/24 08:53 PM
05/04/24 08:53 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Vipers are not new cars and I'm not saying this to argue. Only to educate that I've seen the difference and sharing my reasons why I think it's better.
Axles or control arms is almost the same as wheel or tire securement. Either allows the suspension to absorb the bumps in the road. I used to tow alot of Mopars with a strap forward from the K member. This is not bad because it's pretty horizontal, not quite chaining a frame downwards on an angle.
Interested on hearing why you think frame is better.
By the way. E tracks is very easy to use. Especially for "old guys" The system secures onto the track, over the tire, onto the track then a clip is used to change the strap from a vertical pull to a horizontal pull. Which will be a ratchet mechanism any distance away like 2 or 3 feet.
Re: Enclosed car trailersI [Re: Magnum] #3231126
05/05/24 11:25 AM
05/05/24 11:25 AM
Rhinotruck
Rhinotruck
I do NOT think tying it down by the frame is better, in fact Reliable used the holes in the frame of a survivor 69 Daytona bringing it to the MCACN show a couple years ago and ripped 6" tears in the frame! I just don't like the e-track with wheel straps in enclosed trailers because it is hard to the straps buckled correctly on the e-track, it is simple on open trailers! Us old fat guys only bend to much in enclosed trailers...
A-Body's RULE!
Re: Enclosed car trailersI [Re: Rhinodart] #3231194
05/05/24 05:37 PM
05/05/24 05:37 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I just installed a set of these on the rear . with HD ratchet straps going straight back to the floor D rings
A chain in the front hooked to axle straps looped thru the K frame down thru the D rings on the floor across and up thru the opposite side to the 2nd strap. And a chain binder going side to side between the D rings to pull the chain tight. It aint going anywhere
Page 3 of 3 1 2 3
