2004 Dodge Ram 5.7 ETC reset #3228850
04/23/24 10:46 PM
04/23/24 10:46 PM
AndyF Offline OP
AndyF  Offline OP
I had the battery in my 2004 Ram die while the truck was parked. Got the battery replaced and then the ETC light flashes and the engine has a rough idle. I found a procedure for resetting the ETC, basically just turn the key on, cycle the gas pedal to WOT and back and then turn the key off. Is that all it takes or is there more to it?
Re: 2004 Dodge Ram 5.7 ETC reset [Re: AndyF] #3228864
04/24/24 12:53 AM
04/24/24 12:53 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I believe you have to turn the ignition on then slowly press the pedal 3 times, (not sure if that's accurate or not) then turn off the ignition.
Re: 2004 Dodge Ram 5.7 ETC reset [Re: SNK-EYZ] #3228978
04/24/24 05:12 PM
04/24/24 05:12 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
[video:youtube]https://www.youtube.com/watch?[/video]
Jump to 11:50 for resetting.
My Monster are real!
Living within your means makes life pretty easy.
Re: 2004 Dodge Ram 5.7 ETC reset [Re: SNK-EYZ] #3229128
04/25/24 01:54 PM
04/25/24 01:54 PM
AndyF Offline OP
AndyF  Offline OP
I just cycled the gas pedal once time to the floor and back then turned the ignition back off. I waited a few moments for everything to update and then turned the key back on and started the engine. The check light turned off and the engine idle was fine so I took it for a short drive. Everything seemed to work fine.
