Luggage Rack Mounting #3228775
04/23/24 01:23 PM
04/23/24 01:23 PM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Hi
Had a rough time pulling the luggage rack off my Barracuda.
The captured nuts (see attachment) kept turning.
I can get to the back of all but one with vice grips.
What options do I have for the unreachable one?
I have a nut sert tool, can I justs squeeze the factory insert?
Should I remove the factory insert and replace it with a nut sert?
Any other ideas would be appreciated.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Luggage Rack Mounting [Re: Hrtbkr] #3228784
04/23/24 01:36 PM
04/23/24 01:36 PM
New State
kidmopar Offline
kidmopar  Offline
New State
Do you plan on keeping "factory nut serts" ? shruggy
IF ..... you can remove them ? I'd just get standard nut serts & install .........
