rear springs 2935064 #3228199
04/20/24 01:28 AM
04/20/24 01:28 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
came across the springs and would like to know what they fit ,
part no stamped bottom leaf 2835064 ?
thank you !
Re: rear springs 2935064 [Re: calrobb2000] #3228228
04/20/24 09:53 AM
04/20/24 09:53 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
drive Hi , wave , 1968 and 1969 A-Body Mopar 340 Vehicles . But will fit other A-Body Years or engine combos . drive
Re: rear springs 2935064 [Re: 1969ronnie] #3228348
04/20/24 10:59 PM
04/20/24 10:59 PM
s. e. pa.
s. e. pa.
hi
thank you !
was supprised to see 8 ply each side kind 0f heavy
are they for stick or auto ?
Re: rear springs 2935064 [Re: calrobb2000] #3228614
04/22/24 03:46 PM
04/22/24 03:46 PM
1969ronnie Offline
1969ronnie  Offline
Hi wave , If those have 8 Leafs per side , Somebody added some leafs because Factory 2835064 are 6 Leaf Springs and measure 35" front segment center Eye to center bolt , and Rear Segment is 20" from Rear Eye to Center Leaf Spring Center Bolt . drive Post what You have for Spring Measurements ? Did somebody add those A-Body Springs to another Spring Pack to make 8 Springs ? shruggy
Re: rear springs 2935064 [Re: 1969ronnie] #3228619
04/22/24 05:22 PM
04/22/24 05:22 PM
A727Tflite Online content
A727Tflite  Online Content
Front segment is 20”. All A Body and SS springs.
Re: rear springs 2935064 [Re: 1969ronnie] #3228682
04/22/24 11:55 PM
04/22/24 11:55 PM
s. e. pa.
s. e. pa.
hi
8 ply
i think your measurements are bass awkards 20 front for a bodys !
Re: rear springs 2935064 [Re: calrobb2000] #3228693
04/23/24 02:24 AM
04/23/24 02:24 AM
What is the cast in (Stamped) number on the other spring?
Depending on which motor was in the A body back then had a lot to do with which rear leaf springs they got, 6 cyl. and 318 cars got different ones than the 340 automatic cars got and the 340 4 speed car shad different ones(6 leafs on the passenger side on the 340 automatic cars and 7 leaf's on the driver sides on the 4 speed car, same thing on the 383 cars also. scope shruggy
Re: rear springs 2935064 [Re: Cab_Burge] #3228807
04/23/24 05:59 PM
04/23/24 05:59 PM
1969ronnie Offline
1969ronnie  Offline
drive Whoops , Yup I reversed My measurements . No Biggie . wave Saying HI to Cab , Cab But A-Body Springs did NOT do the 6 springs on 1 side , and 7 Springs on the other side . That is a B-Body Leaf Spring thing mostly , drive So What are Your Spring Measurements , and WHY do You have 8 Leaf Springs ? We NEED Spring Measurements to help HELP You ! bump
Re: rear springs 2935064 [Re: 1969ronnie] #3228854
04/23/24 10:52 PM
04/23/24 10:52 PM
s. e. pa.
s. e. pa.
hi
front 20or 21 depends on how you measure them with 8 plys for sure ,
