HHR fan, stock wiring and alternator question
#322827
05/19/09 03:53 PM
05/19/09 03:53 PM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
My permacool fan(that only draws about 5/6 amps)is kinda beat up from coming loose doing wheelstands over the years Anyhow, i have stock factory alternator(70 Duster)and stock wiring harness. I have a digital 6, holley volumax 250 pump, trans brake(not using it currently)and an electric water pump. Anybody see any problems upgrading to the HHR fan? I am unaware of what its current demands are, but it seems like a super upgrade if i can get away with it TIA
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: HHR fan, stock wiring and alternator question
[Re: B3422W5]
#322828
06/17/09 10:53 AM
06/17/09 10:53 AM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
bump 4 ya Don
I'll add: Is the HHR fan a single speed or 2 speed?
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: cudarex]
#322830
06/17/09 11:24 AM
06/17/09 11:24 AM
B3422W5
Portage,michigan
I have stock wiring and stock alternator..that was what i was wondering, would it cause me problems with juice..i would intend to put a relay across it and run it off my existing toggle switch I have had no problems with my existing permacool, but it doesnt move much air and is an "open" fan with no shroud. It upside is that it only draws 4 or 5 amps. Just trying to get ready for Pinks and possibly back to back passes and want to stay cool
[Re: cudarex]
#322832
06/17/09 02:40 PM
06/17/09 02:40 PM
Posts: 3,095 Idaho
Runner
Idaho
Not sure the amp rating on a stock alt. but shouldn't be any lower than my 60 amp. As long as your using a relay shouldn't be a problem with the wiring. I pulled my hot wire from the post on the starter relay with a switch on the trigger wire to the relay. The shroud on these really helps.
ill add that i was able to race 2 days with my permacool fan with out having any battery issues but with the hhr fan i need to charge the battery some or ill have issues on the second day. my battery cant keep up with the between rounds cooling for more than 1 day with out getting charged. i bought a generator last weekend to solve this problem.
