Re: Need help identifying this 4-speed
[Re: toast253]
#3228035
04/19/24 10:55 AM
04/19/24 10:55 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Castings numbers , which you posted mostly aren't really good for identifying a trans other than platform specific pieces as all the maincases will have the same number .
But that said the one where I can somewhat see the tailhousing and it's a 69 down B body tail housing , is it a 23 spline or 18 spline input shaft ?
8 31 67 is the CASTING date , there are no plates screwed to the castings , what you see as screws are the identifiers screwed into the mold itself.
is there a flat machined pad on the right side of the trans ? Need to see what casting number is on the bearing retainer , the casting date points to a 68 model year trans.
[Re: toast253]
#3228353
04/20/24 11:14 PM
04/20/24 11:14 PM
JohnRR
U.S.S.A.
Ahh, gotcha now, thank you Well , what is stamped on it , that is the pertinent information? Picture says you have a 68 model year Hemi 4 speed for a B body.
[Re: JohnRR]
#3228622
04/22/24 05:55 PM
04/22/24 05:55 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
Ahh, gotcha now, thank you Well , what is stamped on it , that is the pertinent information? Picture says you have a 68 model year Hemi 4 speed for a B body. That being a 68 makes me think somebody has been inside it. That side cover looks like the 70 T/A & 71 up interlock side cover. If you are going to use it I would suggest you do a little deep dive in it and see if it has been done right or patched.
[Re: IMGTX]
#3228710
04/23/24 08:36 AM
04/23/24 08:36 AM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Ahh, gotcha now, thank you Well , what is stamped on it , that is the pertinent information? Picture says you have a 68 model year Hemi 4 speed for a B body. That being a 68 makes me think somebody has been inside it. That side cover looks like the 70 T/A & 71 up interlock side cover. If you are going to use it I would suggest you do a little deep dive in it and see if it has been done right or patched. For sure, the side cover is an interlock side cover, not a ball and detent.
[Re: Cuda340]
#3228716
04/23/24 09:47 AM
04/23/24 09:47 AM
JohnRR
U.S.S.A.
Ahh, gotcha now, thank you Well , what is stamped on it , that is the pertinent information? Picture says you have a 68 model year Hemi 4 speed for a B body. That being a 68 makes me think somebody has been inside it. That side cover looks like the 70 T/A & 71 up interlock side cover. If you are going to use it I would suggest you do a little deep dive in it and see if it has been done right or patched. For sure, the side cover is an interlock side cover, not a ball and detent. I thought the cover looked off , that's a down grade , why would someone do that ???
[Re: JohnRR]
#3228747
04/23/24 11:48 AM
04/23/24 11:48 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
To get the stronger steel shifting forks?
[Re: Cab_Burge]
#3228771
04/23/24 01:14 PM
04/23/24 01:14 PM
Cuda340
Wheatfield, NY
To get the stronger steel shifting forks? Cut the nubs off and use them in with the ball and detent side cover.
[Re: Cuda340]
#3228799
04/23/24 04:20 PM
04/23/24 04:20 PM
JohnRR
U.S.S.A.
To get the stronger steel shifting forks? Cut the nubs off and use them in with the ball and detent side cover. Exactly that's what I have done before , now Brewer and Passon offer steel forks without the nubs.
