Re: The elusive D/W series 26x21 440 ac rad
[Re: poorboy]
#3228177
04/19/24 10:20 PM
04/19/24 10:20 PM
Posts: 699 Southern Alberta
Uberpube
Southern Alberta
Checked theirs. Everything but the 21" And connections are incorrect.
[Re: Uberpube]
#3228306
04/20/24 04:10 PM
04/20/24 04:10 PM
Posts: 10,552 Freeport IL USA
poorboy
Freeport IL USA
Checked theirs. Everything but the 21" And connections are incorrect. I'm sure they would alter the location of the radiator hoses if the shorter height could be used, if you contacted them directly instead of using their generic on line reference. May be a slightly higher price.
[Re: Uberpube]
#3228340
04/20/24 09:23 PM
04/20/24 09:23 PM
Posts: 4,740 Star Idaho
67vertman
Star Idaho
Yeah Griffin doesn't have one either. I need more cooling which is why I want an aluminum rad, so no interest in switching to a shorter 18" rad. The truck has a 505 in it that made 549 hp, AC will be used and the truck is on 37's so I want to get as much cooling into as I can. A rad shop measured the tanks and said they can't add any more core thickness than what I have, I may end up buying a buy an LS Swap style rad for it. LS stye or custom built may be your only options. There used to be a company that made custom radiators in brass style, but for the life of me I cannot remember their name.
My Monster are real!
Living within your means makes life pretty easy.
[Re: Uberpube]
#3228341
04/20/24 09:27 PM
04/20/24 09:27 PM
67vertman
Star Idaho
Might try these guys....https://www.northernradiator.com/HIGH_PERFORMANCE/SEARCH_BY_CATEGORY/HIGH_PERFORMANCE_RADIATORS/MUSCLE_CAR_RADIATORS/FORD_-_MOPAR_RADIATORS/205132
