Eagle wagon...
#3227049
04/14/24 03:32 PM
04/14/24 03:32 PM
Posts: 977 Colorado
dssaa
Colorado
Re: Eagle wagon...
[Re: moparjim79]
#3227213
04/15/24 02:19 PM
04/15/24 02:19 PM
Posts: 977 Colorado
dssaa
Colorado
Deal of the month for somebody Hopefully going to check it out today....
Re: Eagle wagon...
[Re: not_a_charger]
#3227219
04/15/24 03:11 PM
04/15/24 03:11 PM
Posts: 1,722 Chicagoland
Cooter
Chicagoland
Is there an easy way to swap in a high/low range transfer case instead of the single speed t-case these came with? Yes. Mine had a swapped NP231, AW-4, and a Renix 4.0 stroked to a 4.5, but the t-case swap can be done by itself.
Re: Eagle wagon...
[Re: Cooter]
#3227263
04/15/24 08:48 PM
04/15/24 08:48 PM
Posts: 19,970 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
Is there an easy way to swap in a high/low range transfer case instead of the single speed t-case these came with? Yes. Mine had a swapped NP231, AW-4, and a Renix 4.0 stroked to a 4.5, but the t-case swap can be done by itself. That thing is fantastic!
Earning every penny of that moderator paycheck.
DBAP
