Re: 30* Timing? [Re: clovis] #3227133
04/15/24 02:46 AM
04/15/24 02:46 AM
i like to see the timing mark on the ground strap in the middle of the curve, not down low next to the spark plug body scope up twocents
Other than that that plug looks good to me up bow grin
Re: 30* Timing? [Re: Cab_Burge] #3227203
04/15/24 01:12 PM
04/15/24 01:12 PM
moparx Offline
moparx  Offline
so looking at that ground strap colorization, which way does the timing need to go ? more or less ?
beer
Re: 30* Timing? [Re: moparx] #3227222
04/15/24 03:22 PM
04/15/24 03:22 PM
I'm not sure so I would put one new plug with the same # and install it in #7 and advance it 4 degrees and go drive it at light throttle cruise and check it to see where that line ends up wrench up
Please let me know what it likes scope
Re: 30* Timing? [Re: CSK] #3227240
04/15/24 04:41 PM
04/15/24 04:41 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Originally Posted by CSK
the thing with electronic ign is some they advance & some retard as the rpm goes up, you check the total @ 3k & its 30deg, but @ 6k it could be 34 degrees
U are correct...
I have found different mopar ECUs will vary the timing, sometimes advance and/or retard up to +/- 4 degrees..
Thats why when changing an ECU, one needs to recheck the timing both initial and total...
Just my $0.02... wink
