70 Back - B Body - Cars For Sale - 2nd Quarter #3223928
03/31/24 11:24 AM
03/31/24 11:24 AM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
1969 Hemi Dodge Charger [Re: moparts] #3224126
03/31/24 09:46 PM
03/31/24 09:46 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Putting my 69 Charger up for sale. Please read the entire add before asking questions. Sorry about the pictures I am not much of a camera man but I will answer all questions. Message me here for any information or contact number.
1969 Hemi Charger.
Not an original Hemi car.
528 Hemi.
Runs on premium pump gas.
Dynoed at 642 HP and 650 TQ.
New MP Iron Block and heads.
Stage 2 head porting.
Indy roller rockers.
New rocker shafts and stands.
Custom push rods.
New oil pump.
New oil pan and sump screen.
Comp Cam flat tappet hydraulic.
Mopar performance single carb aluminum intake.
Polished Indy aluminum valve covers with breathers.
TTI ceramic coated headers
TTI 3 inch h-pipe exhaust.
Bungs welded in collectors for O-2 sensors.
Pro Systems carburetor.
Carter HP mechanical pump with fuel gauge.
Mopar performance air cleaner.
New fuel tank, sender, lines.
Fuel gauge calibrated.
Mancini ready to run distributor.
MSD coil
Moroso custom wires
Custom serpentine belt drive.
Aluminum water pump and housing.
125 Amp one wire alternator
Mini starter.
Cold case radiator and fans.
Custom polished ss recovery bottle.
All new radiator and heater hoses.
Classic auto air system.
Firm feel stage 2 gear box.
New power steering pump and hoses.
Complete front suspension rebuild all Moog parts.
Offset upper control arm bushings for better caster adjustment.
Firm feel solid tube tie rod adjusters.
Original Hemi K-frame and engine brackets and mounts.
K-Frame blasted and powder coated.
All suspension parts blasted and powder coated.
Firm Feel HD torsion bars
New front shocks.
Precision steel drive shaft 1350 joints.
TKO 600 5 speed .64 OD.
Complete 5 speed conversion kit from Keisler.
Sachs clutch rated for 700 HP.
Clutch and brake pedals, mount, braces all restored.
All new pedals and pads.
Strange Dana 60, Locker 3.73, gears.All new. Dr Differential
Ford SVO rear disc brakes with park brake.
Wilwood front discs.
All new brake lines and hoses.
New master cylinder and proportioning valve.
Torque thrust 2 wheels.
BFG tires
New rear springs.
New rear shocks.
All new wiring front to rear.
New AMD front and rear bumpers.
All bumper brackets blasted and powder coated.
All new tinted glass.
All new cat whiskers.
New vinyl top.
All stainless trim professionally restored and polished.
New remote control mirror.
All new name plates/emblems.
All new locks and keys.
Restored fuel fill tube.
All new vent hoses.
New fuel fill cap and door with bezel.
New trunk mat.
Jack and hardware restored and powder coated.
New upper and lower door panels.
New carpet.
New under carpet sound deaden-er pad.
Custom carpeted floor mats with Charger lettering.
New sill plates and extensions.
New outer and inner door handles.
All seat frames blasted and powder-coated.
Rear seat professionally restored with new legendary covers.
Front seats professionally restored with new legendary covers.
New front headrests with all new hardware.
All seat hinge covers and knobs are new.
All new seat belts.
All console plates and hardware is new.
New shift boots.
Factory AM-FM radio.
New antenna.
New front and rear speakers with fader.
Factory cluster with tachometer professionally restored.
Voltmeter conversion.
New speedometer cable.
Speedometer calibrated correctly within 2 mph by radar.
Steering column restored.
New turn signal switch.
New wood grain wheel.
Dash frame blasted and power coated.
New dash pad.
New A-pillars.
New visors.
New headliner with insulation.
New back seat divider panel with sound deaden-er pad.
New rear shelf with sound deaden-er pad.
New inside rear window trim.
New window cranks.
New arm rests and chrome bezels.
All internal door and window hardware restored.
All new weatherstripping.
All new hood, inner fender, core support seals.
New hood mounted turn signals and wiring.
Restored wiper motor.
All wiper linkage restored, Bushings replaced.
New washer bottle, pump, hoses nozzles.
Grille professionally restored.
Grille frame blasted and power-coated.
All new grille trim and hardware.
Electronic headlamp door openers.
Headlights run off relays.
Body completely striped, soda and other media to a bare shell.
Fenders, doors, hood and trunk done the same.
New American made factory quarters. Not from China.
New trunk floor.
New trunk extensions.
New driver front floor pan.
Rest was normal metal finish with zero rust.
Welded in frame connectors.
Added Hemi rear torque boxes,rear shackle and pinion floor reinforcements.
Car was a Colorado car barn stored since 1990.
Overall a very clean car.
Originally a base model 383, automatic, 8 3/4 rear.
Completely painted inside and out B5 Blue.
Outside completely done base coat clear coat B5 Blue.
Custom Matte black 528/HEMI Tail stripe.
The underside is as clean as the outside.
Front end computer aligned with print out.
Have build sheet and fender tag. All body numbers match.
200 miles since completed.
I am getting older and have lost interest, only reason for selling.
120,000.00 Car sold as is where is. No warranties expressed or implied. Clear title in my name. All funds must clear before the car moves. Inspections welcome. Will help load. No shipping on my end. Buyer needs to supply shipper.
100_2485 (2).JPG (2519 downloads)
100_2482 (2).JPG (2514 downloads)
Re: 70 Back - B Body - Cars For Sale - 2nd Quarter [Re: moparts] #3224347
04/01/24 05:49 PM
04/01/24 05:49 PM
ny
Q
quill Offline
quill  Offline
Q
ny
1964 Plymouth Savoy. 2Dr Post 4 Speed Rolling Chassis. K Frame Redone with Polyurethane Bushings, Front Disc Brakes, New Brake Lines, including Hoses, New Shocks. Late Model Rear with 392 Sure Grip 11 inch Backing Plates, Shoes and Drums, New Gas Tank and Sending Unit, New 3/8″ Fuel Line. Interior was all Soundproofed including Doors. All Glass was removed, all Window Mechanisms were Cleaned and Reinstalled. Windshield and Rear Glass have New Gasket. Radio Delete New Engine Wiring Harness. $21,000 OBO South Carolina Title. Car located New Bern NC Email- jany63@optonline,net
1969 Sport Satellite Pro Street Project 25k obo [Re: moparts] #3227929
04/18/24 04:10 PM
04/18/24 04:10 PM
Clarksville, TN
toast253 Offline
toast253  Offline
Clarksville, TN
Selling my 1969 Sport Satellite Pro Street Project. I have had this car since 1996 and it was my daily driver in High School but unfortunately, I do not have the funds or time to finish the project. I am getting out of the military soon and need to start downsizing. The car has been sitting for a while and does have some surface rust, but no metal pitting. I will try to list everything as best as I remember. I have a lot more pictures as well. The pictures are not great, but absolutely everything that was on the car when I was daily driving it is still there in the bins. The only thing I can think of that might be missing is a body wiring harness, belts, and some gaskets maybe. I do have the clean title in hand.
The body:
Paint will need to be finished...jams, engine bay, and hood.
Full Cage with swing outs. Cage is punched through the firewall, not welded to it
Sub-framed
Tubbed
4-Link suspension
Trans Tunnel
POR rust protectant on the underside
DYNAMAT in the interior
All metal work is complete, and all gaps and lines are perfect.
All glass is included; however, it is original and kind of hazy.
Battery re-location kit
Fuel cell and fuel tank included depending on the direction you want to go.
Original seats front and back in perfect condition as well as some Corbeau front seats that need some cleaning.
Original steel hood and Fiberglass lift-off hood
All original Gages, dash, trim, bezels, bumpers, lights, etc. included.
New GTX grill and badging (perfect condition) included as I was going to make it a clone.
The Engine:
Original numbers matching 383 can be included.
440 build - never been assembled, block will need to be tanked for clean-up - all machine works complete. Should spec out around 700 hp when built.
Indy Heads
Indy high rise single plane intake
Eagle Crank
COMP Cam
COMP Roller rockers
ARP Head Stud kit and all gaskets
MDS 6AL Ignition
TTI Ceramic coated headers
All pulleys, pumps, alternators, plugs, ignition wires, etc. included.
727 Transmission – was rebuilt with a shift kit, but probably needs a clean up after sitting
Drivetrain:
Dana 60 with Strange 4.56 Spool - Never used.
Yukon Axles - Never used.
Drag Star Wheels - tires were never used, however are dry-rotted. Good enough to get it home but not good enough to drive on.
Flow master mufflers (don't remember if they are 20 or 30 series)
Strange Coil Overs
Wildwood full brake kit - Never installed.
This is all I can remember for now. I have a lot more pictures available that I can send if anyone is interested. Unfortunately, I am not able to deliver or help much loading due to a recent shoulder surgery. No Trades Please.
1967 Dodge Coronet 440 original paint [Re: toast253] #3230101
04/29/24 11:26 PM
04/29/24 11:26 PM
MI
I
IROC78 Offline
IROC78  Offline
I
MI
SOLD THANKS MOPARTS !
Re: 70 Back - B Body - Cars For Sale - 2nd Quarter [Re: moparts] #3230354
04/30/24 09:38 PM
04/30/24 09:38 PM
Rochester NY
TheMoparKid Offline
TheMoparKid  Offline
Rochester NY
Considering selling my 1969 Dodge Superbee
Numbers matching 383, 4 speed, 8 3/4, 3.91suregrip. Factory B5 with white stripe and black interior. Manual steering and brakes. A real muscle car! Original Fender tag and broadcast sheet. Very straight body and nice paint. Nice interior. Original floors, no rust! Asking $60k obo Located in Webster New York 14580
Walk around video available
1968 CHARGER R/T 440 AUTO "XS29L8" [Re: moparts] #3230860
05/03/24 06:55 PM
05/03/24 06:55 PM
ORANGE PARK,FL
gdmusclecar Offline
gdmusclecar  Offline
ORANGE PARK,FL
68 DODGE CHARGER R/T 440 AUTO,REAL "XS29L8" CAR,THE ENGINE IS NOT THE ORIGINAL ENGINE,ITS A C440 67 440 ENGINE WE DID GET THE ENGINE TO CRANK,WE HAVE NOT CHECKED THE TRANSMISSION TO SEE IF ITS THE ORIGINAL TRANSMISSION OR NOT,THE INTERIOR IS COMPLETE,DASH,DOOR PANELS,HEADLINER IS VERY NICE,IT HAS THE ORIGINAL WRAPPERS ON THE REAR SEAT BELTS,DASH VIN,FENDER TAG, BUILDSHEET IS ALL THERE,THERE IS NO TITLE,THERE WAS NO OPTION TO CLICK ON FOR NO TITLE,IT WILL COME WITH A BILL OF SALE,A TITLE COMPANY CAN GET YOU A TITLE.THE WORST PART OF THE CAR IS IT WLL NEED MOST OF THE SHEET METAL REPLACED,THE FLOORS,TRUNK PAN,FRAME RAILS AND TORSION BAR CROSSMEMBER IS RUSTY,THIS IS A MAJOR PROJECT AND NO IT DOES NOT RUN AND DRIVE,AND THIS IS AN EXTREMELY RARE CAR.
$25,000
ORANGE PARK,FL.
EMAIL: GDMUSCLECARPARTS@YAHOO.COM
PH# 904-589-4645
68 C1.jpg (1211 downloads)
68 C3.jpg (1210 downloads)
68 C9.jpg (1210 downloads)
68 DODGE CORONET R/T 440-4SPD CONVERTIBLE [Re: moparts] #3230865
05/03/24 07:12 PM
05/03/24 07:12 PM
ORANGE PARK,FL
gdmusclecar Offline
gdmusclecar  Offline
ORANGE PARK,FL
68 Dodge Coronet R/T 440-4 Spd Convertible
***1 of 88 built***
68 Dodge Coronet R/T Convertible 440-4spd,3.54 Dana 60,date coded drivetrain rebuilt,new 15 x 7 magnum 500 wheels,new tires,new brakes,new convertible top,hydralic cylinders,lines,new interior,new chrome bumpers.Too much to list,factory blue car with black interior.
Orange Park,Fl.
Price $89,000
email:gdmusclecarparts@yahoo.com
ph# 904-589-4645
Re: 1968 CHARGER R/T 440 AUTO "XS29L8" [Re: gdmusclecar] #3230868
05/03/24 07:26 PM
05/03/24 07:26 PM
K
KOS Offline
KOS  Offline
K
1970 HEMI Roadrunner Tribute NEW Build
572 Pump Gas 750HP
CRT 727 billet internals Pro torque 9.5"vert
Dana 60 rear with locker 35spline axles and 3.73gears
all original panel car from Nevada
this car was built to be driven/reliable and hold up to some drag strip action if so desired.
pls call/text 289 456 9003 or pm(not on here too often)if interested many more pix and vids available.95k
70 RUNNER TRUNK.jpg (1197 downloads)
70 RUNNER NEW FLOORS.jpg (1199 downloads)
1970 Road Runner Convertible [Re: moparts] #3233043
05/15/24 07:44 PM
05/15/24 07:44 PM
Bristol, CT
RalphsRapidTrnst Offline
Bristol, CT
SOLD 1970 Road Runner Convertible. Sold new at Check Point Chrysler Plymouth in Niagra Canada. I've owned the RR for seven plus years. The RR is #'s Matching Engine. Original EW1 with an FK interior. The RR is mostly original painted TX9 in 1972 The owner installed a 440 that is in it now. It comes with its original 383 short block that has been rebuilt. Build sheet in hand. The interior is original including the carpet. The front bucket seats have been recovered by me with new legendary covers. Floors are nice no issues, trunk floor has ben repaired along with inner aprons have been touched up. The body is nice and looks great the way it is with its period looking paint, graphics and wheels. Outer body panels are reusable, the deck lid lip was rusted and repaired when the car was touched up in the 80's along with the 1/4 panels. 440 Runs very well. I've brought the RR to the Nat's and have used the RR for local cruise nights. Drive the way it is or restore you decide SOLD Thank you Moparts.
A Collection Of All Things Chrysler
www.RalphsRapidTransit.com
Stock Appearing MuscleCar Racing
www.SuperCarRaces.com
Re: 70 Back - B Body - Cars For Sale - 2nd Quarter [Re: moparts] #3233545
05/18/24 01:26 PM
05/18/24 01:26 PM
Kentucky
crboone64 Offline
crboone64  Offline
Kentucky
1966 Hemi Dodge Charger. Original H Code 426 Hemi Car. Great Rolling Project. needs Restored. Very solid underneath. Complete minus Motor and Transmission. $14k OBO.
phone 606-231-3446
