Just looking to show off some G3 goodies.
#3223353
03/28/24 01:35 PM
03/28/24 01:35 PM
Posts: 2,877 SE Nunya
Bubba
SE Nunya
So STEFFCO racing down in SC has been working on this 424NAX GEN 3 HEMI BUILD for me. Check it out. 6.1 Block Thitek Built Eagle Heads 4.07 Bore. 4.08 Stroke. 424 CID K1 Technology Crank & Rods Diamond Custom Pistons 12:5 Pump Gas / MS109 at the Track. Hellcat Fuel Injectors 102MM Throttle Body Holley Intake Johnson Short Travel with Axle Oiling Lifters AAD Aluminum Lifter Guides Milodon Oil Pump Pickup & Pan Manley Timing Chain Mike Jones CAMSHAFT Machine Work was done at Harrell Engines I'm so excited, I just wanted to show off. Simple as that. Bubba
questions. Just looking to show off some G3 goodies.
[Re: Dart451]
#3223535
03/29/24 12:34 PM
03/29/24 12:34 PM
Bubba
SE Nunya
I’ve always had 2 issues that bothered me. Weight and Speed. 1965 Coronet 1980 Mirada 1970 Coronet 2005 Magnum RT 2012 Challenger RT 2006 Jeep SRT
The average weight of these vehicles is 4350 Lbs. Time to be different!
Welcome to my current project. 1987 Chevrolet El CAMINO. Better know for the last few years as the EL HEMINO in my family.
PROJECT: EL HEMINO
424” Gen 3 Hemi T-400 Transmission Ford 9” PTS Fab K-Frame with Rack TRZ Front and Rear Suspension Strange Brakes AFCO Shocks Front and Rear Full Cage 8.50 Cert Full Interior from 1987 All Steel. Even bumpers Hemi Hood Scoop
My intentions are to wheel this thing around the block a few days a week, hit some car shows and definitely the drag strip. I am not chasing numbers, so I don’t care how fast it goes. The car is headed down to SteffCo Racing in SC for all the Cage and Chassis/Frame work next month.
I know it’s not a Mopar on the outside.
[Re: fbs63]
#3223551
03/29/24 02:20 PM
03/29/24 02:20 PM
Bubba
SE Nunya
Re: Just looking to show off some G3 goodies.
[Re: BDW]
#3223577
03/29/24 07:16 PM
03/29/24 07:16 PM
Bubba
SE Nunya
No solid estimates yet. Less than 4K. The PTS FAB Kit is a game changer. Weight / Strength, and headers will be off the shelf.
[Re: volaredon]
#3224147
04/01/24 12:56 AM
04/01/24 12:56 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I like it better than these idiots that want to stick a Chevy motor in everything else, especially these days a freaking "LS something"...... I get so damn tired of hearing about that BS. But a turbo 400? Wouldn't a 727 be a better bet? I don't get the obsession with the turbo 400 either, 727 is just as good. TH400 still explode, still cost big money to handle big HP, almost identical gear ratios, heavier, requires adapter plate or bellhousing, if you put one in a mopar then it don't bolt up to your trans mount and your slip yolk don't fit...
[Re: Bubba]
#3224402
04/01/24 10:54 PM
04/01/24 10:54 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
[Re: Bubba]
#3224739
04/03/24 01:17 PM
04/03/24 01:17 PM
Posts: 17,878 S.E. Michigan
ZIPPY
S.E. Michigan
Not that my opinion means anything, but I like it. Thanks for sharing Bubba.
Rich H.
Esse Quam Videri
[Re: Bubba]
#3224855
04/03/24 07:50 PM
04/03/24 07:50 PM
Posts: 1,408 Central Pa
moparjim79
Central Pa
Who said there was an obsession with a T400? And if there was, wouldn't that state the obvious? I'm not here to debate. 904/727/T400/4L80 Use what makes YOU happy, what YOU pay for, and what gets YOUR job done.
On the other hand, I do have a obsession with my FORD 9".. if anyone would you care to join me? an 8 3/4 to a 9"? Dana 60 to a 9"? I'll take the weight savings from the 9" to make up for the use of a junk T400.
Holley Terminator X setup for all controls. Some of these members are seriously mopar or no car. Good for them. I agree, your money, your car, end of story. Lots of reasons people pick a 9 over any other rear. Keep doing what you're doing.
[Re: Bubba]
#3232109
05/10/24 08:36 PM
05/10/24 08:36 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
What kind of flow numbers did you get out of the eagle heads? I hope to start building a 6.1 stroked to a 426 with around 14.1 compression. I can't decide which is better to use the 6.1 heads or the eagle heads. I have both. Which are both stock and I would like to send them out for porting
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#3232446
05/13/24 05:35 AM
05/13/24 05:35 AM
Posts: 3,874 Smyrna, South Carolina
STEFF
What kind of flow numbers did you get out of the eagle heads? I hope to start building a 6.1 stroked to a 426 with around 14.1 compression. I can't decide which is better to use the 6.1 heads or the eagle heads. I have both. Which are both stock and I would like to send them out for porting Bubba's ported Eagle Heads: Intake Numbers: .10: 76, .20: 141, .30: 225, .40: 293, .50: 340, .60: 364, .70: 378, .80: 380 Heads have 2.125 dia. Intake valves. Never flowed the exhaust side. Stock exhaust valve size
