452 casting #3223190
03/27/24 04:49 PM
03/27/24 04:49 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
hello,
picked up a pair of "452" b/b heads for my stocker, has a 1/8" pipe plug on one end. is this factory? motor home?? never seen this before. also appear to be surfaced quite a bit, casting numbers on deck surface top 1/16th have been machined. deck thickness on lower head bolts is 1.00 thick, what's unsurfaced thickness?
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 452 casting [Re: 440lebaron] #3223199
03/27/24 05:25 PM
03/27/24 05:25 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Originally Posted by 440lebaron
hello,
What kind of spark plugs do those heads use? I’ve heard that uncut heads measure a little over 1”, but I’ve never measured personally shruggy
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: 452 casting [Re: metallicareload] #3223212
03/27/24 07:00 PM
03/27/24 07:00 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Are there steam ports at the exhaust valves? There are two 452 heads. Standard and motor home.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 452 casting [Re: moparmarks] #3223215
03/27/24 07:31 PM
03/27/24 07:31 PM
NY
B1duster Offline
B1duster  Offline
NY
There was someone in Westchester NY selling bare NOS 452 heads on Craigslist or facebook a few months ago. $50 ea. I believe they had 3 pair. I searched but can’t find them now. If I find them I’ll let you know. They were within a 1/2 hr for me.
Re: 452 casting [Re: B1duster] #3223251
03/27/24 10:59 PM
03/27/24 10:59 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I’ll check my heads for that plug but I don’t remember one being there, might be wrong though.
Re: 452 casting [Re: 440lebaron] #3223252
03/27/24 11:04 PM
03/27/24 11:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
906's usually measure 1.00ish from the factory ,I never measured the set I had gotten from Paul Rossi back in the 80's , they were NOS castings , small plug with the water ports around the spark plugs.
What's the depth of the open part of the chamber , the set I had were over .100 , as deep as .130 in the center of the head.
Re: 452 casting [Re: 440lebaron] #3223284
03/28/24 09:16 AM
03/28/24 09:16 AM
an8sec70cuda Offline
The 1/8" pipe plug is factory and I believe to be only on motorhome heads. I just sold a set like that a few weeks ago. I removed them from a 440 that came out of a motorhome.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 452 casting [Re: an8sec70cuda] #3223297
03/28/24 10:43 AM
03/28/24 10:43 AM
westerly, ri. usa
westerly, ri. usa
regular spark plug no taper, no steam holes, chamber depth measures .063
was there a calculation for surface milling for cc reduction?
Re: 452 casting [Re: 440lebaron] #3223302
03/28/24 11:01 AM
03/28/24 11:01 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The outer head bolt row is usually a reliable indicator for head milling.
Uncut heads will be right about 1.00” thick.
Re: 452 casting [Re: fast68plymouth] #3223308
03/28/24 11:15 AM
03/28/24 11:15 AM
AndyF Offline
AndyF  Offline
Yeah, one inch is what I used to use as the gauge when I bought and sold cast iron heads. If the calipers read 1.00 or higher I assumed they were uncut heads. I can't say I've ever seen a factory drawing for the heads but it seems to be a good rule of thumb.
Re: 452 casting [Re: 440lebaron] #3223349
03/28/24 01:24 PM
03/28/24 01:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
.063 says to me it's been cut , I've never seen an open chamber head that shallow... is the open part of the chamber floor parallel to the deck surface ? That almost looks angle milled , which I've never heard being done to a big block wedge head?
Re: 452 casting [Re: JohnRR] #3223355
03/28/24 01:38 PM
03/28/24 01:38 PM
westerly, ri. usa
westerly, ri. usa
casting area by number is at a angle chamber is flat
Re: 452 casting [Re: 440lebaron] #3223497
03/29/24 08:57 AM
03/29/24 08:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The one set of NOS castings I had , the Paul Rossi heads , were the peanut plug /extra cooling holes version and the chambers were .110 to . 130 deep.
CC the head , if it's less than 90-92 cc it's been cut.
Re: 452 casting [Re: an8sec70cuda] #3223530
03/29/24 12:04 PM
03/29/24 12:04 PM
Anchorage, Alaska
Anchorage, Alaska
Starting to sound like these are some type of motorhome heads. The 452 heads I used on my 440 doesn’t have that boss drilled and tapped. It also took flat/gasket spark plugs
440, 4-Speed, 3.54
Re: 452 casting [Re: 440lebaron] #3223542
03/29/24 01:33 PM
03/29/24 01:33 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
I have a few with the plug and also steam holes in th deck, it seems it was for the HD application, RV's, trucks and police cars. S/F....Ken M
