452 casting
#3223190
03/27/24 04:49 PM
03/27/24 04:49 PM
Posts: 1,608 westerly, ri. usa
440lebaron
westerly, ri. usa
hello, picked up a pair of "452" b/b heads for my stocker, has a 1/8" pipe plug on one end. is this factory? motor home?? never seen this before. also appear to be surfaced quite a bit, casting numbers on deck surface top 1/16th have been machined. deck thickness on lower head bolts is 1.00 thick, what's unsurfaced thickness?
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: 452 casting
[Re: 440lebaron]
#3223199
03/27/24 05:25 PM
03/27/24 05:25 PM
Posts: 271 Anchorage, Alaska
metallicareload
Anchorage, Alaska
hello, picked up a pair of "452" b/b heads for my stocker, has a 1/8" pipe plug on one end. is this factory? motor home?? never seen this before. also appear to be surfaced quite a bit, casting numbers on deck surface top 1/16th have been machined. deck thickness on lower head bolts is 1.00 thick, what's unsurfaced thickness? What kind of spark plugs do those heads use? I’ve heard that uncut heads measure a little over 1”, but I’ve never measured personally
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
Re: 452 casting
[Re: 440lebaron]
#3223252
03/27/24 11:04 PM
03/27/24 11:04 PM
Posts: 75,069 U.S.S.A.
JohnRR
U.S.S.A.
906's usually measure 1.00ish from the factory ,I never measured the set I had gotten from Paul Rossi back in the 80's , they were NOS castings , small plug with the water ports around the spark plugs.
What's the depth of the open part of the chamber , the set I had were over .100 , as deep as .130 in the center of the head.
Re: 452 casting
[Re: 440lebaron]
#3223284
03/28/24 09:16 AM
03/28/24 09:16 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
The 1/8" pipe plug is factory and I believe to be only on motorhome heads. I just sold a set like that a few weeks ago. I removed them from a 440 that came out of a motorhome.
Re: 452 casting
[Re: an8sec70cuda]
#3223297
03/28/24 10:43 AM
03/28/24 10:43 AM
440lebaron
westerly, ri. usa
regular spark plug no taper, no steam holes, chamber depth measures .063 was there a calculation for surface milling for cc reduction?
Re: 452 casting
[Re: 440lebaron]
#3223302
03/28/24 11:01 AM
03/28/24 11:01 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The outer head bolt row is usually a reliable indicator for head milling.
Uncut heads will be right about 1.00” thick.
Re: 452 casting
[Re: 440lebaron]
#3223349
03/28/24 01:24 PM
03/28/24 01:24 PM
JohnRR
U.S.S.A.
regular spark plug no taper, no steam holes, chamber depth measures .063 was there a calculation for surface milling for cc reduction? .063 says to me it's been cut , I've never seen an open chamber head that shallow... is the open part of the chamber floor parallel to the deck surface ? That almost looks angle milled , which I've never heard being done to a big block wedge head?
Re: 452 casting
[Re: JohnRR]
#3223355
03/28/24 01:38 PM
03/28/24 01:38 PM
440lebaron
westerly, ri. usa
casting area by number is at a angle chamber is flat
Re: 452 casting
[Re: 440lebaron]
#3223497
03/29/24 08:57 AM
03/29/24 08:57 AM
JohnRR
U.S.S.A.
casting area by number is at a angle chamber is flat The one set of NOS castings I had , the Paul Rossi heads , were the peanut plug /extra cooling holes version and the chambers were .110 to . 130 deep. CC the head , if it's less than 90-92 cc it's been cut.
Re: 452 casting
[Re: an8sec70cuda]
#3223530
03/29/24 12:04 PM
03/29/24 12:04 PM
metallicareload
Anchorage, Alaska
The 1/8" pipe plug is factory and I believe to be only on motorhome heads. I just sold a set like that a few weeks ago. I removed them from a 440 that came out of a motorhome. Starting to sound like these are some type of motorhome heads. The 452 heads I used on my 440 doesn’t have that boss drilled and tapped. It also took flat/gasket spark plugs
