Re: '07 6.1 to '70 Barracuda [Re: Cheeto] #3222546
03/24/24 02:15 PM
03/24/24 02:15 PM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
Originally Posted by Cheeto
...pulled the Barraucda out of it's 3+ year slumber ...
Does it still count as a "barn find" if it was in a 4 bay garage where 2 bays were used for hay storage and I'm the one that put the car there? work
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: '07 6.1 to '70 Barracuda [Re: Cheeto] #3230573
05/02/24 01:34 AM
05/02/24 01:34 AM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
More progress...
Donor engine is out, intake is off to powder coat, Holley Terminator engine harness had one sub-harness that wasn't correct for the car but that got ordered today after the Barracuda was dropped off. Correct dipstick for the new pan as well as Holley exhaust manifolds also ordered. Transmission guy happened to be at the shop and we discussed the 46RE. He's starting on it tomorrow. Last major part to order is a radiator. Leaning towards Cold Case with shroud/fans but I need to do some measuring on the car since the CC website isn't super clear on exactly how/what their rads fit and I can't recall which side the hoses are on the donor engine or their sizes.
RE: the 46RE...last year I found a thread (possibly a different forum) showing where a couple ribs/nubs etc. needed to be trimmed off the trans case for clearance. Can't seem to find those images now. Any guidance appreciated.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: '07 6.1 to '70 Barracuda [Re: Cheeto] #3230580
05/02/24 06:29 AM
05/02/24 06:29 AM
BDW Offline
BDW  Offline
Re: '07 6.1 to '70 Barracuda [Re: BDW] #3230659
05/02/24 01:38 PM
05/02/24 01:38 PM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
Thank you! This appears to be 2 different "webs"? I was thinking it was 1 web and 1 ear.
Side note: I'm getting old...can somebody point me in the right direction to change the font size for Moparts? I've had good success on other forums but not here.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: '07 6.1 to '70 Barracuda [Re: Cheeto] #3230667
05/02/24 03:30 PM
05/02/24 03:30 PM
BDW Offline
BDW  Offline
That's my 518/46RH behind a 5.7 in a Challenger.
I had swapped in the OD with a 340, drove that 7 yrs, then bolted in the 3G with no changes.
The RE may be slightly different on the case?
Re: '07 6.1 to '70 Barracuda [Re: Cheeto] #3230912
05/03/24 11:50 PM
05/03/24 11:50 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Cheeto, click on the down arrow next to your screen name at the top right of this page.........
Click on 'preferences'..........
Then scroll down until you see 'Your Preferred Forum Style (aka Skin/Theme)'.......
Scroll down to 'ubbthreads L type'
This will make everything a bit bigger (I'm getting old too).
If there is a way to change JUST the font, I'm not aware of it.
Once you make the change, don't forget to click 'save changes' at the bottom of the preferences page.
beer
John
Re: '07 6.1 to '70 Barracuda [Re: SattyNoCar] #3232801
05/14/24 04:00 PM
05/14/24 04:00 PM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
That seems to have worked on the Forum but not when I'm typing a response. Is changing the font size every time I respond the only option there (here)?
Cheeto
It's not perfect.
It's not correct.
It's not yours!
