8 3/4 truck rearend
#3221258
03/18/24 05:24 PM
03/18/24 05:24 PM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I posted a while back about a 8 3/4truck rear It has tapered axels. With a large nut out side the drum All I want from this is the housing and center section. Already have new axels So my question is. How do I tear this thing down? If remove large nut. How does the axel come out?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: 8 3/4 truck rearend
[Re: toplescuda]
#3221271
03/18/24 06:15 PM
03/18/24 06:15 PM
Posts: 5,783 ohio
ruderunner
ohio
Take the nut off. Rent or buy a hub puller to get the drums off.
Continue removing nuts and bolts until something falls off.
Angry white pureblood male
[Re: ruderunner]
#3221286
03/18/24 07:37 PM
03/18/24 07:37 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Ok. Put it this way.....what exactly holds the axels in place?
[Re: toplescuda]
#3221296
03/18/24 08:04 PM
03/18/24 08:04 PM
Posts: 10,130 A Red State
SNK-EYZ
A Red State
Probably the same 4 nuts and studs that hold the axles in on any other 8 3/4 rear end.
As already stated, you have to pull the drums first to get at any of it.
The main difference is that the hub flange/drum assembly is held on by the nut on the end of the axle flange instead of the axle flange having the wheel flange being forged as part of the axle.
[Re: SNK-EYZ]
#3221307
03/18/24 09:07 PM
03/18/24 09:07 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
So the flange with the wheel studs. Is not the axel?
[Re: toplescuda]
#3221313
03/18/24 09:34 PM
03/18/24 09:34 PM
SNK-EYZ
A Red State
So the flange with the wheel studs. Is not the axel? Yes and no, it is not the actual axle. The axle is in the center of it is the axle and the nut holds the flange on the axle. You have to remove the nut, then the brake drum/hub assembly with a puller. Here's a link to some info with pics from another forum. https://www.google.com/url?sa=i&...CBUQjhxqFwoTCLjg2-CW_4QDFQAAAAAdAAAAABAEThere's pics of a service manual stuff there.
[Re: SNK-EYZ]
#3221320
03/18/24 09:54 PM
03/18/24 09:54 PM
Posts: 6,233 nowhere
Sniper
nowhere
It's a two piece axle. You have an axle shaft and an axle flange. No great mystery here, Chrysler used this setup till 64 in pass cars, later in trucks. You have to remove the nut to pull the flange. . You have to pull the flange to unbolt the bearing retainer to pull the shaft. You will need a GOOD puller to get the hub off. The kind you use a 5lb sledge on. When I did this to my 51 Plymouth I had to let the puller sit overnight under pressure before I could get passenger side flange off. This is the puller https://www.amazon.com/gp/product/B074QQCTH8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
[Re: toplescuda]
#3221342
03/19/24 02:55 AM
03/19/24 02:55 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
Ok. Put it this way.....what exactly holds the axels in place? The bearing retainer on the axle bolts up to the axle housing Same bolts hold the brake backing plate on also. Be prepare to fight getting the left brake drum off even with a great puller Good luck
[Re: Cab_Burge]
#3221417
03/19/24 12:31 PM
03/19/24 12:31 PM
Posts: 19,366 north of coder
moparx
having taken many of those drum/axle combos apart, using the puller, some come apart relatively easy, while others are a complete mofo [even with the puller] to get apart. plan on a complete afternoon, or longer, to get them apart. or just find and install a 66-72 complete truck rear and be done with it. [as i have done countless times] just my opinion. your mileage will vary.
[Re: moparx]
#3221524
03/19/24 07:59 PM
03/19/24 07:59 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Well i dont have a puller but buddy does have a cutting torch Being all I actually need/want is the housing and center pig.... can I cut the drums off?
[Re: IMGTX]
#3221549
03/19/24 09:57 PM
03/19/24 09:57 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Use a torch and cut the face off of the drums and you can unbolt the axles and then just keep what you need...
Everything you're not going to use is not something you're likely to sell to anyone else anyway...
You will need to get a set of 65 up car or later truck backing plates with drums in a matching set...
10" or 11" whatever you want to use with wheel cylinders and a hardware kit...
...FAFO...
[Re: B1MAXX]
#3221609
03/20/24 09:10 AM
03/20/24 09:10 AM
Cab_Burge
[Re: Cab_Burge]
#3221639
03/20/24 11:47 AM
03/20/24 11:47 AM
Posts: 528 SW CO
HemiSportFury
SW CO
I've had good luck putting the puller on it under a good load (tension) and then heating the hub with a torch and letting it sit over night. The next morning they basically fall off. This has working on hubs that have been on for over 50 years.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: B1MAXX]
#3221796
03/20/24 10:03 PM
03/20/24 10:03 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
I hear ya but I cant believe that a sledge won't take it off in a few whacks if we're not trying to save anything from the backing plate out. Have you ever removed one of the tapered axle drums before? I watched my boss, with 25 years of experience working on those tapered axle drums destroy an axle shaft trying to remove a drum once. He had all the correct equipment and he used every trick he had ever learned and it still didn't work. Sometimes they just don't come apart. He ended up cutting the drum and removing the brake shoes to get the axle out and replaced that axle with a junk yard axle shaft and drum.
