Page 5 of 5 1 2 3 4 5
Re: Now: 66 Hemi Satellite survivor [Re: tboomer] #3221136
03/17/24 08:23 PM
03/17/24 08:23 PM
So Cal
autoxcuda Offline OP
So Cal
Originally Posted by tboomer
That looks good! Did you re-use the factory bolts? up
Reused the bolts that were there. Seemed factory but looked like three different brands/stamps
I used Justice Brothers Engine Degreaser. Seemed to work better than brake clean or concentrated simple green. It was best when surface dry between applications/follow-ups. I used an air nozzle to dry. Then scrub. Then spray with hand spray bottle with water set to stream. The agitated greas-grime and degreaser would shoot off surface when the shot of water stream hit it. Then slide and dip off to a pan underneath.
Used dishwasher brush, small stiff bristle shop brush, engine cleaner bottle brushes.
Re: Now: 66 Hemi Satellite survivor [Re: autoxcuda] #3222393
03/23/24 06:15 PM
03/23/24 06:15 PM
So Cal
So Cal
Thinking about buying a group 27 repro battery.
What is the difference between early 65-68? red top and later 69-72? battery.
I have a late one with green tops I’m debating gutting and putting a small mini battery inside
They sell red tops separate ?
This is what I have. It’s got a 29…. Part number
Re: Now: 66 Hemi Satellite survivor [Re: autoxcuda] #3222415
03/23/24 08:23 PM
03/23/24 08:23 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
My gut feeling is cap color has something to do with cold cranking amps maybe. or manufacturer year,,,,or both
I went with red caps
