Re: 383 vs 440 flywheel
[Re: AndyF]
#3220846
03/16/24 04:12 PM
03/16/24 04:12 PM
Posts: 2,536 God's Country Maryland
GODSCOUNTRY340
383's were internally balanced, 440's with a steel crank were internally balanced so those flywheels will interchange; Now, cast crank 440's were externally balanced so those won't interchange with a 383.
[Re: GODSCOUNTRY340]
#3220850
03/16/24 04:26 PM
03/16/24 04:26 PM
Posts: 25,982 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Some '70-'71 383's were externally balanced and so were some steel crank 440's with heavy rods.
[Re: John_Kunkel]
#3220852
03/16/24 04:35 PM
03/16/24 04:35 PM
GODSCOUNTRY340
You're probably right John but I've never seen a 383 with a cast crank, even the 2 bbl. engines I've had were steel cranks and internally balanced.
[Re: IMGTX]
#3220868
03/16/24 05:21 PM
03/16/24 05:21 PM
Posts: 6,323 nowhere
Sniper
nowhere
In addition to the balance weren't the pressure plate sizes often different? 10.5 vs 10.95/11 inch. it's 10.5/10.95" vs 11" First two use the smaller sized flywheel, latter uses the bigger flywheel.
[Re: rapom]
#3220878
03/16/24 06:12 PM
03/16/24 06:12 PM
Posts: 31,076 Oregon
AndyF
There are a lot of different flywheels, maybe six or more? between those two engines. Small clutch, big clutch, internal balance vs. external balance and then the 440+6 type of flywheel which is another variation of the external balance.
If you have a 130 tooth, internal balance flywheel you should be able to swap it between multiple Mopar engines including SB, B and RB. But only if the rest of the assembly is compatible. (bellhousing, clutch, rotating assembly balance, starter, etc.)
[Re: rapom]
#3221247
03/18/24 03:52 PM
03/18/24 03:52 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
The flywheel and bellhousing are from a 70 383 from a challanger r/t. The 440 is from a 1978 motorhome. I wanted to install the 440 on an engine test stand and run it. The flywheel and bellhousing are needed to start it. The bellhousing and flywheel will bolt on, but you will need an external balance flywheel for that year 440.
[Re: rapom]
#3221371
03/19/24 09:40 AM
03/19/24 09:40 AM
Sniper
nowhere
Figures, Well thanks for the info guys. At least I will be able to mock up my test stand while searching for a flywheel. No need to search. 440 source has a new billet flywheel, 130 tooth, and an add on weight for cast crank applications. Touch base with them to verify 440 cast crank. Under $250.
[Re: rapom]
#3221382
03/19/24 10:15 AM
03/19/24 10:15 AM
Posts: 4,704 Wichita
GY3
Wichita
Figures, Well thanks for the info guys. At least I will be able to mock up my test stand while searching for a flywheel. 440 Source has a balance weight that converts a flywheel from neutral balance to external cast crank balance for the rock bottom price of $25.00 Part # 200-1168
#3221514
03/19/24 07:17 PM
03/19/24 07:17 PM
Posts: 43,621 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
You're probably right John but I've never seen a 383 with a cast crank, even the 2 bbl. engines I've had were steel cranks and internally balanced. I have two 71 383's with cast cranks, but everything I have read is that they were for automatic transmissions only...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#3221579
03/19/24 11:33 PM
03/19/24 11:33 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
You're probably right John but I've never seen a 383 with a cast crank, even the 2 bbl. engines I've had were steel cranks and internally balanced. I have two 71 383's with cast cranks, but everything I have read is that they were for automatic transmissions only... The 1971 two barrel 383 motors got those cast cranks is what use to be said at the oild drag race seminar that Mopar put on before 1980
