Re: toll used to hold pinion yolk while torqueing nut ?
[Re: moparx]
#3220189
03/13/24 01:34 PM
03/13/24 01:34 PM
Posts: 25,969 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A large pipe wrench works to hold the yoke.
[Re: John_Kunkel]
#3220204
03/13/24 02:34 PM
03/13/24 02:34 PM
Posts: 1,757 Phila
PhillyRag
Phila
[Re: topside]
#3220274
03/13/24 08:12 PM
03/13/24 08:12 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
I made one that bolts on now, but have always used a large pipe wrench as mentioned above also.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Neil]
#3220308
03/13/24 10:56 PM
03/13/24 10:56 PM
Posts: 31,074 Oregon
AndyF
I have one that looks like yours in the middle there. Think I bought it off Mancini's (?) website many years ago. Could be. I've been selling parts to Mancini for more than 20 years.
[Re: moparx]
#3220311
03/13/24 11:23 PM
03/13/24 11:23 PM
Posts: 1,366 Out of the State of Confusion
blue_stocker
This was a short piece of left-over roll bar tubing with a piece of 1/4" plate, clearanced rectangle around the companion (pinion yoke); works quite well!
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
[Re: John_Kunkel]
#3220326
03/14/24 01:29 AM
03/14/24 01:29 AM
Posts: 43,293 Bend,OR USA
Cab_Burge
that is what I use. MoparX which third member are you working on? If it is a "489" case then you need to know how much rotational torque it has both ways now before you loosen the nut up so you can tighten it back up enough to have 1 to 5 inch lbs. MORE rotational torque when your done
[Re: cudaman1969]
#3220345
03/14/24 08:23 AM
03/14/24 08:23 AM
Posts: 6,322 nowhere
Sniper
nowhere
My 35 year old 110 electric Makita is ALL I’ve ever used, never once has a nut backed off (a little red loctite helps too) Beautiful, except the OP was asking how you hold the yoke when you are torquing the pinion nut. I hope you aren't using that same Makita for that.
[Re: Cab_Burge]
#3220405
03/14/24 01:25 PM
03/14/24 01:25 PM
Posts: 19,599 north of coder
moparx
that is what I use. MoparX which third member are you workoing on? If it is a "489" case then you need to know how much rotational torque is has both ways now before you loosen the nut up so you can tighten it back up enough to have 1 to 5 inch lbs. MORE rotational torque when your done working on a 741 case that is still in the car Cab. i'm not a fan of using a pipe wrench due to the possibility of the teeth marking up the yoke. i had thought about making a tool like the several that have been shown. i'll probably do just that, although as i get older, i find there is no such thing as a 5 minute [or 5 hour for that matter] job.
[Re: 69Cuda340S]
#3220519
03/14/24 11:26 PM
03/14/24 11:26 PM
Cab_Burge
[Re: Sniper]
#3220577
03/15/24 11:05 AM
03/15/24 11:05 AM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
My 35 year old 110 electric Makita is ALL I’ve ever used, never once has a nut backed off (a little red loctite helps too) Beautiful, except the OP was asking how you hold the yoke when you are torquing the pinion nut. I hope you aren't using that same Makita for that. I use my hand to hold the yoke, take a hammer and hit a nail hard, the nail drives into the wood, now a slow tap on the nail, no move. The Makita works on same principal as the fast swinging hammer! It’s called FORCE, kinetic energy
