combo advice
#3218879
03/07/24 04:26 PM
03/07/24 04:26 PM
Posts: 191 WI
mopar873
WI
Hi Guys,
I'm helping my father with his drag car. I know it's Brand X, but the question is still relevant. The car combo is a 4link, '66 Chevy II with a Heidt's coil-over front end. It currently sits on 31x14 tires with a 'glide and a 5.14 gear, approximately 2500lbs. I have a line on a very fresh 312" sbc comp engine. It was built and maintained by a very well known and successful Comp Eliminator racer. It is a 13 degree head combo. We were originally going with a 393" combo which is a high-winder but nothing like this 312. Other than going to a deeper rear gear, I'm looking for some advice on converter shops to key on for a foot-brake combo like this. I've done tons of reading and opinions on the net are like belly buttons on who is good, bad, or up and down. The rpm range of the engine will be about 8k-9800rpm. I haven't pulled the trigger on it yet, because I'm not convinced its a better option for us than a 393 combo with 15 degree heads. What is making me even consider it is the price. I understand the level of maintenance to be expected, what we were already planning on was going to be a heavy-effort combo too. I just wonder how the reduced torque in the smaller engine will narrow or widen the window to perfect the way the suspension works. I would think the reduced torque would soften it up, but only if the converter is spot-on.
Re: combo advice
[Re: mopar873]
#3219072
03/08/24 11:48 AM
03/08/24 11:48 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
If it were me, I would put it on a dyno (I am bias) and get some numbers before talking to a converter guy, unless you like pulling transmissions and shipping converters back and forth.
Joe
Without Data, you’re just another guy with an opinion.
Re: combo advice
[Re: mopar873]
#3219084
03/08/24 01:01 PM
03/08/24 01:01 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
IMO pretty simple choice, A1 as high winding SB's are their bread and butter. They would want a dyno sheet or at the very least some previous performance numbers and details. But I can tell you the dyno sheet is a much better start. Those two engines will require two different converters, just to much stroke difference to not require two.
Re: combo advice
[Re: mopar873]
#3219090
03/08/24 01:18 PM
03/08/24 01:18 PM
Al_Alguire
Las Vegas
A lot of factors play in slr numbers, IMO there is no "magic slr". Don't get to hung up on it its gonna want what it wants based on power numbers and where they occur. That little engine is likely going to want a fair amount MORE slr than the bigger armed one for sure. This is pretty much and apples to oranges deal honestly. I am sure the TQ numbers are significantly different in number and RPM. Id think that little engine would want to be over 11 for sure
Re: combo advice
[Re: mopar873]
#3219116
03/08/24 03:14 PM
03/08/24 03:14 PM
Al_Alguire
Las Vegas
Happy to help anyway I can. feel free to PM me if oyou like happy to look over data etc..
