For Sale - Race Cars - 1st Quarter #3202063
01/03/24 08:41 PM
01/03/24 08:41 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Shelby Dakota #216 [Re: moparts] #3205332
01/16/24 07:03 PM
01/16/24 07:03 PM
Rehobeth
W
Warfish340 Offline
Warfish340  Offline
W
Rehobeth
Roller only
WILL TRADE FOR A NICE A BODY STEEL/GLASS RACECAR
$20000obo OR TRADE
South Alabama
Real Shelby #216
Setup for a smallblock on front and mid plates
Truck is mini-tubbed.
Has 29x10.5 tires now but will hold much larger if needed.
RC Comp beadlocked rear wheels
Weld 2.0 front wheels.
All basically new tires
Has a 6pt cage.
Full Shelby interior, dash, and glass
4" Glasstec Cowl hood
8gal Twist lid fuel cell with return.
Aeromotive Eliminator Brushless fuel pump
Aeromotive pressure regulator
All braided line front to rear
Setup on a return system
Dana 60 rear
Girdle cover
4.88 Strange gear
35 spline Moser Axles
5/8 Studs
Factory disc brakes front
Aerospace disc brakes rear
Cal-Trac mono leaf suspension
Viking double adjustable rears
QA1 coilover conversion on front
Precision PPP Shifter
Custom shifter mount
Motion Raceworks Steering Wheel
Lineloc
Mopar manual master cylinder
MSD Digital 6 Plus Box
MSD HVC II Coil
Custom Steel Roll pan
Optima Red Battery
TONS more.
Truck is super nice and super clean.
Could easily be put back on the street.
You don't see many Shelby Dakota Race Trucks this nice and clean.
Currently with a 410" small block it runs 6.30-6.40 in the 1/8th shifting at 6400rpm.
Truck is well documented and have several videos on our channel.
https://youtu.be/Xt-zQolmmTs?si=YdXbhBVZLa9DJgWc
https://youtu.be/b5EP3cE-h7s?si=yw7IrlapumBBWbP-
Re: For Sale - Race Cars - 1st Quarter [Re: moparts] #3208111
01/25/24 03:07 PM
01/25/24 03:07 PM
Pittsburgh Pa
Viperizer Offline
Viperizer  Offline
Pittsburgh Pa
2002 Jerry Bickel Dodge Viper
Ready to race top sportsman / bracket car it is very basic, Nothing fancy, very light weight, simple to run 7.50 quarter / 4.50 1/8 with ease. Very reliable drivetrain. Fiberglass body. Tons of carbon fiber throughout. Lamb Struts/ brakes Weld wheels 110" WB. Racepak recorder with 8 exhaust sensors, driveshaft, fuel oil etc. sensors. Mega 450 delay box, JBRC fab ford 9" rear end. Air charged chute. Engine is 540" Aluminum Keith Black water block, 572 Indy heads, Indy Tunnel ram. Crowler billet crank . long billet rods . small light weight gas drilled JE pistons. Titanium valves, Jesel rocker system and Timing Belt. Stefs oil pan/ reservoir. Stock Car products dry sump pump. Coated Hooker headers.
Glide with JW bell house, JW case, Best at the time BTI internals, Pro clutch pack, Aburrizi Pro light Valve body, Cheetah Shifter, Chance bolt together aluminum convertor. Car has been well maintained, stored in climate controlled garage for many years. Car has never been damaged in any fashion, drivetrain has never been damaged in any fashion. Engine and trans rebuilt every season. Needs nothing, will come with new slicks and front runners, couple N20 bottles.
I will separate drivetrain from chassis. Chassis 55k , engine 35, trans/convertor 5k
Fun car to race! Go fast like the big motor guys , just with out all work and hassle ... Add fuel and go! Me and my wife did it together with ease, lost her in 2012 and stopped running the car then, just not the same. Time for it to go...
Will trade for credit towards the following cars : Lambo Huracan or Aventador / Ferrari 488 or F8 , Viper Comp Coupe or Gen 5
Dodge Sealth Race Car $21,500 [Re: moparts] #3211628
02/07/24 06:53 PM
02/07/24 06:53 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Nice tube frame race car with fiberglass 2001 Dodge Stealth body. 9” with aluminum center section gear 4.10. 500cid low deck with B1heads. Big dominator Holley with ported heads and intake. Motor was built by Muscle Motors. Had approximately 120 passes on motor. Custom headers with Borla mufflers. Roller cam, dual swinging oil pickup and pan. 727 with Griner brake, steel drum and new converter. Trans is fresh with about ten passes. MSD ignition and distributor, Delay box. Goes nice and straight with no issues. Not raced since 2010. Just stored in shop. New fuel lines. Will need tires. Car goes 5.60 in 1/8 at 125. 8.80 in 1/4. $21,500. Car is located in Abilene, Texas.
Pm me for number to call.
Mark
*************SALE PENDING**************************
Re: For Sale - Race Cars - 1st Quarter [Re: moparts] #3215809
02/24/24 12:29 PM
02/24/24 12:29 PM
York,Pa
Slap Shot Online work
Slap Shot  Online Work
York,Pa
being sold as a roller no engine or trans we have a engine and a couple automatic trans if needed.
1965 Dodge Coronet factory A-990 Super Stock Hemi race car 1 of 101 made W051 vin lightweight factory Ruby Red car with great history. this A-990 Dodge was never restored and was a running and driving race car until 2 months ago it has been repainted unlike many of the restored A-990 cars this one has the original vin tag,original fender tag and still has both body numbers that match the fender tag and still has other special A-990 only factory body modifications. does have some corning glass and light weight body parts and original door panels,2 super stock seats that fold forward and aluminum seat brackets will need interior finished up the carpet is out but comes with new carpet and a trunk full of parts including radiator and drive shaft.
some owners
Johnny Perkins The Chinese Bandit out of Jesup,Georgia
Barnett automotive Steve Bagwell car driven by Terry Earwood out of Atlanta,Georgia
Bobby Crouse from Murray,Kentucky
Bill Weekley Ohio
$75,500 does have a title to the car. 717 577-0270
Re: For Sale - Race Cars - 1st Quarter [Re: Slap Shot] #3216360
02/26/24 02:36 PM
02/26/24 02:36 PM
Santa Fe TX
aspen7709 Offline
aspen7709  Offline
Santa Fe TX
1970 Plymouth CUDA Drag car. Set up for Big Block/ Small Block(headers and motor plates for both) Auto or STD ( both crossmembers and a clutch pedal) 9in Ford/ 5:13 moser axles and internals all new tires (14x32 will take 15x33.5)Cragar Super Star Wheels. Spare rears with tires Wilwood front brakes w/ line lock , tubular front suspension w/ coilovers Art Morrison Ladder bar rear Suspension w/ coilovers and wheelie bars. Parachute Steel roof and quarters/ fiberglass front, doors, deck and 2 hoods, lexan windows.
Painless wiring, MSD7, Autometer gauges
Aeromotive fuel System 4 gallon cell.
Mild steel funnycar cage, was certified, JAZ seat
2950 w/ 200lb driver will fit 6' plus
Paint shows well but it is racecar. Proven car for 25 years, hooks hard goes straight.
Car has NO TITLE BILL OF SALE ONLY
and before you ask :NO, IT ISNT STREET LEGAL and CANT BE PUT BACK ON THE STREET EASILY willing to trade for: 62-65 mopar B-body 2dr SEDAN (NSS)
70-74 mopar e-body street car
NHRA Stock Eliminator Car (must be .500 under) $28K ROLLER $33K TK w/ mild 360 (7.50's in the 1/8) $38K TK w/360 AND X-block W2 355 in pieces needs built.
or best REASONABLE OFFER
Located in Santa Fe TX. Could Transport for extra $ or meet half way for trades.
stock7709@gmail.com Kenny 480-233-0688
Overkill is Under-rated....
