69 1/2 roadrunner upper core support plates, for hood pins.
#3215003
02/20/24 07:48 PM
02/20/24 07:48 PM
Posts: 836 Missouri
galen
Missouri
I put a fiberglass hinged A12 hood on my 68 gtx clone. I would like to put in these upper radiator support plates for the 69 1/2. For my hood pin mounting. Question without having a 69 in front of me are the plates in the picture part of the inner fender? I can't find just the brackets listed or used. Or a picture of your hood pins on a 68 would be appreciated.
Re: 69 1/2 roadrunner upper core support plates
[Re: galen]
#3215043
02/20/24 11:48 PM
02/20/24 11:48 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
BTW nicely done illustration of the hood pin location..............wonder who did it Thank You. That is much appreciated by the way. And thanks for pointing that out on the fenders. I may need to fabricate something similar. You are best off fabbing a bracket to hold the pin in place as you can't just cut those brackets off a 69 fender and put them on a 68. I had a 68 front clip grafted on my 69 RR decades ago and there was a lot of fab work to remove the 68 corner brackets and graft in the 69 upper core support ends so the 69 fenders were a bolt on.
[Re: JohnRR]
#3215131
02/21/24 01:35 PM
02/21/24 01:35 PM
Posts: 836 Missouri
galen
Missouri
I Thanks for the replies. I always appreciate the advice on this website. I will fabricate some brackets and post some pictures. Not a restoration in any way. it started life as a 318 2 bbl sport satellite. I purchased it as a GTX clone many issues but a rust free car. Finally after 6 years I am going to body and paint this weekend. i'm 66 this is my last major project.
[Re: galen]
#3215157
02/21/24 03:07 PM
02/21/24 03:07 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
If you could find a couple 1969 fenders, usually even some totally rotted out ones will have the "ashtrays" still intact.
There are a few spot welds holding them on to both styles, cut (tiny belt sander) or drill the spot welds and they interchange.
I converted one Plymouth fender from a 68 to a 69 using a rotted out 69 "parts fender". Besides the side marker hole and the ashtray needing to be changed, the '69 also has a small welded grille mounting bracket that needs to be swapped over.
It would probably save time to just fabricate something, and my hat's off to you for trying to install the pins in the right place. (Can't tell you how many cars I've seen with the pins installed closer to the middle of the core support, nowhere near the factory location).
Good luck
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3215169
02/21/24 03:54 PM
02/21/24 03:54 PM
Posts: 20,894 A collage of whims
topside
A collage of whims
That's a mean-looking car ... Being that it's a modified, non-#s build - not a strict restoration - why not just use the '68 hood bumper location for the hood pins ? Damn near nobody would have an issue with that, if that matters, and the location's close enough to "pass".
[Re: topside]
#3215174
02/21/24 04:08 PM
02/21/24 04:08 PM
Posts: 21,540 N.E. OHIO, USA
A12
N.E. OHIO, USA
That's a mean-looking car ... Being that it's a modified, non-#s build - not a strict restoration - why not just use the '68 hood bumper location for the hood pins ?Damn near nobody would have an issue with that, if that matters, and the location's close enough to "pass". Have to add a plate to the '68 as the hood pin hole and plate on the repro or OE Lift-Off-Hood are in front of the radiator support. The LOH (hood) pin holes will not align with where it is possible to mount the pin on the '68 pad.
