Re: WIW pair of 67 Barracuda fenders
[Re: formula_s]
#3211776
02/07/24 10:49 PM
02/07/24 10:49 PM
Posts: 16,546 On the run…
BloFish
On the run…
If they are indeed that clean, $400 each.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3211942
02/08/24 12:47 PM
02/08/24 12:47 PM
Posts: 43,637 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
If they are indeed that clean, $400 each. That is cheap these days, I would say $800 each knowing they fit the 68 too with little modification. I have seen some for sale locally for $1200 each... ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif)
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#3212362
02/10/24 12:19 AM
02/10/24 12:19 AM
Posts: 28,621 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
If they are indeed that clean, $400 each. That is cheap these days, I would say $800 each knowing they fit the 68 too with little modification. I have seen some for sale locally for $1200 each... Jim aren't you aware that the 67 fenders fit the 68 AND the 69 ? Only difference is is the side marker light. And you can cut in any side marker size you want
[Re: 340SIX]
#3212574
02/10/24 07:21 PM
02/10/24 07:21 PM
Rhinodart
Rhinotruck
Rhinotruck
If they are indeed that clean, $400 each. That is cheap these days, I would say $800 each knowing they fit the 68 too with little modification. I have seen some for sale locally for $1200 each... Jim aren't you aware that the 67 fenders fit the 68 AND the 69 ? Only difference is is the side marker light. And you can cut in any side marker size you want Of course I know that, but most people I know don't have the skills to cut and weld in the 69 marker light area but they do have the ability to use a hole saw to make the 68 marker light fit... ![work work](/ubbthreads/images/graemlins/custom/work.gif)
A-Body's RULE!
