Column lower bearing removal #3203449
01/09/24 05:12 PM
01/09/24 05:12 PM
templeton,ma
coro500net Offline OP
templeton,ma
I have a 69 A body and have column out of the car. Want to replace lower bearing but don’t want destroy everything around it getting it out. Anybody have easy way to remove? Thanks!
Re: Column lower bearing removal [Re: coro500net] #3203450
01/09/24 05:16 PM
01/09/24 05:16 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Remove the screw holding it in and it should come out without too much trouble. If it has an exposed shoulder try grabbing that with a pair of water pump pliers and twisting it out.
Re: Column lower bearing removal [Re: coro500net] #3203542
01/10/24 09:33 AM
01/10/24 09:33 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Who are you getting the replacement from?
Re: Column lower bearing removal [Re: 6PakBee] #3203636
01/10/24 04:47 PM
01/10/24 04:47 PM
templeton,ma
templeton,ma
I’m not putting the $100 factory bushing in, using the roller bearing that everyone is taking about.
Tried twisting old bushing out but won’t move. I guess I can drill a bunch of holes in it to weaken it.
Re: Column lower bearing removal [Re: coro500net] #3203975
01/12/24 03:59 AM
01/12/24 03:59 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My '69 Barracuda came from the factory with a nylon retainer that holds the lower ball bearing, not a bushing. The nylon retainer is two pieces glued together. You can defeat the glue with a razor blade, razor knife, thin hobby saw, thin flush cut dowel saw, etc. See razor blade in photo. I think that's all I used. Simply press out the bearing from the nylon retainer by hand or with a press. If you can't get the nylon retainer out of the column tube after removing the 2 screws, use a hammer rod or drive it out from above with a long bar. You can buy a special nylon glue when you want to re-assemble the retainer.
I can't remember now, but I might have re-greased the bearing without removing it from the nylon retainer.
I put 160,000 miles on my car before disassembly, and all steering column bearings were good after re-greasing. If your bearing is completely worn out (maybe not likely), maybe if you can get all the dimensions of the bearing with a digital caliper, you can buy a standard bearing from a bearing supplier for a reasonable price. If the bearing is rusty, but you can force it to move slightly, you might be able to restore it by removing all grease with brake cleaner, and insert powered household cleanser like Ajax or Comet on the balls and races and work it back and forth. This will remove most or maybe all of the rust in maybe an hour or so of back and forth. If necessary, you can add a little dilute phosphoric acid. Clean and grease. I've restored several rusty distributor advance plate ball bearings that way. Of course this bearing restoration is only good for very low rpm bearings that aren't severely pitted.
Re: Column lower bearing removal [Re: kentj340] #3203976
01/12/24 04:51 AM
01/12/24 04:51 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
One screw on the apex side of the triangular cover, first photo. Second screw on flat side of triangular cover, second photo.
Re: Column lower bearing removal [Re: kentj340] #3204163
01/12/24 07:13 PM
01/12/24 07:13 PM
moparx Offline
moparx  Offline
were those bearings commonly used in any other columns that used bearings on that end ?
beer
