Re: A Body - Cars For Sale 1st Quarter
[Re: moparts]
#3211172
02/06/24 04:30 PM
02/06/24 04:30 PM
Posts: 71 Mid-Michigan
abodybill
Mid-Michigan
1966 Plymouth Valiant V100 wagon 225 Slant six 3 speed on column
SOLD SOLD SOLD
1969 Road Runner 1985 D250 pickup
1972 Demon 340
[Re: abodybill]
#3213127
02/12/24 08:52 PM
02/12/24 08:52 PM
Posts: 542 Louisville, Ky.
Mojoluv
Louisville, Ky.
I have a 72 Demon 340 for sale. This is an H-code project car that needs restored. The car was in storage since 1978. A guy bought it from the original owner and took it apart and started to restore it. He lost his storage and I purchased the car. I have since found a 71 that I would rather fix since I already have another 72, so this car is for sale. It is a very solid car but will need some metal work. Trunk well has had a prior repair, needs lower rear quarters, trunk drop offs, and pass side rocker. The prior owner had already repaired the front floor pans and did a decent job. Frame rails, tortion bar crossmember, and rest of the car is very nice. This is a complete NUMBERS MATCHING engine and trans car. Everything is there for the most part as it was unbothered when he took it apart. The engine and trans are now out of the car and the engine is apart. It is a Rally Red car with white stripes. Has the black houndstooth style interior. Column Auto with AC. The car has a clear title. It is a roller so can easily be transported. I'm asking 7500obo for the car. It is located in Louisville, KY. I have a friend who transports that can deliver for a fee as well. These are best pics I have at the moment. Can take whatever anyone wants. PM me for my contact info if you are a serious buyer. Thanks
1970 Dodge Dart Swinger 340 4 Speed
[Re: Mojoluv]
#3215398
02/22/24 03:10 PM
02/22/24 03:10 PM
Posts: 1,091 Georgia
Matt M
Georgia
1970 Dodge Dart Swinger 340 4 Speed EV 2 Orange with Black Interior.
Original Survivor
All numbers matching. Original Paint Original Interior Original Glass Original Spare Ownership history from day one, lots of dealership paperwork.
This car has not been restored and shows some age and wear on the paint as can be expected with a 54 year old car.
Runs and drive great. I have a lot of photos and a few videos of the car, If you are serious about buying the car you can contact me for more information.
$32,500
Car is located in Spanish Fort (near Mobile) AL You can contact me at miller 3504 pir @ gmail .com
Thanks for the ad Moparts
SOLD
67 Barracuda 383 Formula S Original paint day 2 car
[Re: moparts]
#3215697
02/23/24 10:05 PM
02/23/24 10:05 PM
Posts: 1,008 Central US
grancuda
Central US
1967 Plymouth Barracuda Formula S 383/Auto Fastback
A true Survivor with day 2 modifications
383 Commando V8/727 car
Matching VIN/Data Plate/Radiator Support Stamping/build sheet (partially remaining)
‘71 440 block 10.25:1 compression Edelbrock Performer heads - 83cc Forged pop-up pistons .060 overbore Comp XS282S Solid Cam Crane Gold aluminum 1.5 rockers Carter Mechanical fuel pump Mechanical water pump/fan ‘64 Dual Point tach drive Distributor Accel Super Coil Ported Weiand single plane Holley 850DP carb
Vintage Hooker 1 7/8 fenderwell headers with old 70’s textured high heat coating Vintage Moroso Gold valve covers Vintage to the car Auto Meter Vintage velocity stack & oval air cleaner Oil/Volt/Temp/Trans Temp Vintage Kool Fuel Can NOS Pioneer Super Tuner w/lit bezel AEM Air Fuel gauge
727 auto 3 year since built, approx 4500 miles Hughes 3200 Converter CRT Manual Reverse Valve body B&M Deep Aluminum Finned pan Hurst Quarter Stick
15x3.5” / 15x10” US Indy Mags 8 3/4 rear axles 742 Center Section 3.55 gears Full Spool Yukon Axle Shafts
Original 383 A-body K-member Original 4 piston Kelsey Hayes Disc Original 8 3/4 rear axle housing
Solid car, only rust is on rear passenger lower 1/4. Un-restored exterior, original paint except front clip which was painted in the 70’s. Original rust free floor/trunk pans still intact. Still have factory panels cut from inner fender aprons for the fenderwell headers.
Located 25 miles West of Tulsa OK,
$21k OBO
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
1972 Duster
[Re: grancuda]
#3218141
03/04/24 09:06 PM
03/04/24 09:06 PM
Posts: 5,315 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
UPDATE : * SOLD * 3/24/24
1972 Plymouth Duster
The car is extremely clean
1972 340 block .040 bore ... 418" cubic inches: 10:1 comp. Keith Black Icon forged pistons Scat I beam connecting rods, ARP fasteners throughout engine Eagle 4.00" Forged crankshaft, Pro Products SFI dampener. Billet double roller timing chain Iron "J" casting cylinder heads, are ported and polished. Indy 1.5 ratio roller rockers, Smith Bros. push rods Comp. Cams springs, retainers, locks, seals. Stainless Ferrea 2.02 /1.60 valves Bullet Racing #304000 solid mechanical camshaft, and lifters Mallory Unilite distributor, MSD Blaster 2 coil, and wires. New Orange Control box w/ built in rev limiter Edelbrock 340 Victor intake, ported and gasket matched, Demon 850 carb, rebuilt with new Demon kit. Phenolic carb spacer. Summit 110 GPH electric fuel pump, Holley fuel regulator, 3/8" fuel lines 1-5/8 headers, 3" full exhaust, with Flow Masters. M.P. high volume water pump, Champion radiator, HD trans cooler, factory 7 blade clutch fan, Moroso can
727 Automatic: Koleen/Red Alto parts TCI 3500 stall converter T/A Cheetah manual valve body B&M finned deep aluminum pan B&M Pro shifter Trans shifts firm and tight
15X7" Ralleye wheels Dark argent center caps Stainless polished trim rings Newer Cooper Cobra tires Factory A body 8 3/4 axle #489 center section Richmond 4.10 gear, Auburn sure grip Kelsey -Hayes disc brakes, 10" drums (All rebuilt) New Hotchkiss front sway bar Monroe gas shocks Front Suspension has been rebuilt, 8-9 years ago Newer Espo H.D. rear springs, shackles, hardware BRAND NEW subframe connectors
Interior is restored, excellent condition: Factory 1972 Duster/Demon bucket seats 'Legendary Interiors' front /rear seat covers, foam kits 'Legendary Interiors' front/rear door cards Year One carpets NOS perfect dash pad New woodgrain applique on Instrument face Original one piece headliner Floor shift steering column is restored Factory power steering New Auto Meter tach w/shift light. Auto Meter under dash gauges
Car comes with dealer/factory paperwork: Broadcast sheet, dealership sales invoice, window sticker, original TN. title, owners manual. All paperwork above, is in very good condition and legible. Also envelope full of receipts, cam card, engine shop paperwork, etc. Fender tag is gone.
Thanks Moparts
Plymouth Makes It!
[Re: moparts]
#3218271
03/05/24 12:00 PM
03/05/24 12:00 PM
Posts: 3,457 Newburgh, NY
Old_Moparz
Newburgh, NY
1968 Plymouth Barracuda Convertible Project - $2500
I am listing this car for my friend. I can help answer questions about it but I am unable to discuss anything about the price or making appointments to see it. You can email or call him directly & leave a message. He will reply or return your call. I also have the original photos & more of them in a larger format that I can email you if you need them. (More than 50 photos.)
My email address: oldmoparz2 @ yahoo.com My friend Mark's email address: beepbeep70 @ gmail.com My friend Mark's phone number: 845-895-8678 Call between 9:00 AM & 9:00 PM EST (must leave a message)
The car is located in Wallkill, NY which is in Orange County & about 60 miles north of New York City.
This car was purchased by me about 30+ years ago. It was running, driving & complete, but needed mechanical, body & frame repairs. It had low compression in 2 of the cylinders. I drove it for a short time, sold it to my friend who started to restore it & is now selling it. It's been disassembled, partially sand blasted & some of the parts were refinished. All the removed parts have been stored indoors except the motor & transmission & included with the purchase.
Originally a slant six, auto trans, floor shift, bucket seats, factory sway bar, power top, black interior, wood grain wheel & black convertible top with a bronze exterior. There are two photos of it included from 30+ years ago when I had it. The rest of the photos are in it's current state. The car is currently a rolling shell & must be transported by towing. Very easily accessible by truck or trailer. It will need new sheet metal & frame repairs due to rust. It has a transferrable NYS registration for ownership. (NY state does not issue titles for cars older than 1973.)
