Racing plans for 2024?
#3201831
01/02/24 10:17 PM
01/02/24 10:17 PM
Posts: 1,182 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I'm probably jumping the gun on this, but will throw out a couple of things I have in mind...
First, although I was thinking pretty seriously about getting back into vet motocross, I think that ship has sailed. Instead, I'll do mountain bikes for fun and spend more time at the drags with the two Challengers.
I hit a lot of test & tunes and a few races w/ the 1320 in 2022, but I didn't go once in 2023. I'd told myself the next time I went back to the track should be in the '73... and missed out on the whole year.
The 1320 has one year left of warranty, so I might as well start hitting on it again before that runs out. Just ordered a new set of ET Street Rs for the back to replace the ET Street S/S I ran previously. Unfortunately, one of the S/S has a small abnormality in the tread that acts like a flat spot and "thumps" at higher speeds, so they'll probably get yanked off before they're fully worn out. I was never thrilled with the S/S on this car and am hoping the R provides a bit better consistency. I may also try pulling some weight out of the car at the track to try and keep it in the 11.99 and quicker range.
The '73 runs, but still needs some TLC and some wrenching to be road & track ready. It'll be 2+ months before the local tracks open up again, other than it's possible that Capitol may open for some days in February if the weather is decent. Need to lay out another project plan to nail down exactly what it needs in the mean time. Hmmm...
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Racing plans for 2024?
[Re: Brad_Haak]
#3201842
01/02/24 10:37 PM
01/02/24 10:37 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Good luck with your racing this year. I doubt we'll see a track open here in Minnesota until late April or May. But hopefully I'll make it to Sick Week in Florida the end of this month to get some racing and sunshine! Then in September, Drag Week. Other than that, a bunch of test and tune is all I have planned. At Death Week this year, since I was always in a hurry to hit the road, I didn't make too many passes. Until the last day, when I made about 15 or so. Towards the end. I was hot lapping, trying to advance 1 position before the lanes closed. That reminded me how much I enjoy just making passes. Hopefully I'll be making more than usual in 2024.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Brad_Haak]
#3201843
01/02/24 10:37 PM
01/02/24 10:37 PM
Posts: 20,211 Park Forest, IL
slantzilla
Park Forest, IL
Hoping my knees heal up well. If so my cousin and I will be taking the Valiant out to 41 more this year. I renewed my IHRA number so I can run points.
Car needs to have the motor pulled and the pan leak fixed. This is my old 232 motor, hoping I can run 7.90s or so with it. I'd like to put some 5.13 gears in, don't know if I'll get around to that or not.
[Re: CSK]
#3201859
01/02/24 11:07 PM
01/02/24 11:07 PM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
I got away from points / bracket racing last year and am now pretty much only doing pro tree / index racing .I had a lot of issues last year ( motor problem and a broken driveshaft ) but the car was good late in the year. I really like the .500 pro tree and can hit it pretty well but I lost to many races by not driving the stripe well enough : I plan on changing that !!! I will run 11.50 index and pro dial where I can with the Dart and run at my local tracks nostalgia races with my D150.
[Re: 11secdart]
#3201862
01/03/24 12:07 AM
01/03/24 12:07 AM
Posts: 5,166 CT
GTX MATT
CT
Yes - I didn’t make it to the track in 2023 either. Late ‘22 I got my Plymouth to the track and ran a few 12 second passes with the clutch slipping on the launch. I went a best of 12.56 @ 113 with a very soft 1.79 60 and some very SLOW shifts.
Since the clutch wasn’t too happy launching and I had a TA 3600 conveter I built a torqueflite a couple months ago and put it in. I want to see what it will do with the Torqueflite, hoping and think it should go 11s fairly easily but we will see. I have a set of trickflow 270s and a super victor intake, but I want to see what I can get out of the current combo before I change it. I should install some sub frame connectors and torque boxes before the track opens in April. I need new front tires though, mine are pretty dry rotted. I also just bought a Transgo TF3 kit, I bought a TF2 because I thought the TF3 was reverse pattern with no LBA, but I realized its forward with LBA. So I want to install that in another valve body I have and swap it out as well.
In April I bought a ‘22 Scat Pack Charger I want to bring to the track this spring, and I have a ‘97 Trans Am project I’ve been tinkering with that I’d like to take too, but that needs some brake work and an oil leak fixed.
[Re: GTX MATT]
#3201868
01/03/24 03:01 AM
01/03/24 03:01 AM
Posts: 43,300 Bend,OR USA
Cab_Burge
I sold my old S/P 1970 Cuda two years ago next April or May to a racer in TX. He resold it last year to another racer in Canada. It was a 1970 Cuda chrome Moly tube chassis car that ran a best of 8.86 at 150.+ MPH with me in it at Woodburn 3 yrs. ago, 5.50 at 125.+ MPG in the 1/8 mile at Madras the year I sold it. It weighed 2850 Lbs. with me in it race ready on E85 and would repeat within .003 from 1st to last run all day long on the local pump E85 . I bought a 1973 Duster Bracket car from a guy in Phoenix, AZ that never race it, he thought it He siad it would run mid 13.s in the 1/4 mile which should make it perfect for me to use to teach my youngest granddaughter ( 24YRs. Old) who is married with no kids, drag racing, if she and her husband can drive a drag car at the track and learn to get good at bracket racing . I'm putting my 1965 Dart heads up no prep car on hold until later this spring to have Forest finish the chassis, wheelie bars, headers, mount the motor and tranny and rear spoiler so I can focus on taking a good hard look at the new bracket car to make sure it is safe and ready to race to help teach them, my granddaughter and her husband, drag racing at both ends of the tracks and how to get good at that Time to either send a carb out to have it converted to E85 or buy a new E85 carb for the Duster: confused: Decisions, decisions I think if the Duster has any kind of a decent 360 SB in it, it should run faster than mid 13s, maybe high 11s to mid 11s
[Re: Cab_Burge]
#3201870
01/03/24 06:45 AM
01/03/24 06:45 AM
Posts: 4,704 Wichita
GY3
Wichita
After a year hiatus, our local Kansas International Dragway is opening back up lthis year! So glad to see it open again as it's only 20 minutes from the house and easy for me to do on a Friday or Saturday night.
[Re: GY3]
#3201876
01/03/24 08:34 AM
01/03/24 08:34 AM
Posts: 8,183 Plymouth, MI
Blusmbl
Plymouth, MI
I don't have a ton of upgrade and racing plans for the year. Have some minor things I want to do to the car before Sick Summer in June, hoping to average 11.5x and spray it at each track this year instead of just running on motor. Also need to install the tailpipes + TTI exhaust, fix a pinion seal leak, replace the tailshaft bushing in the trans, and I may also swap over to manual brakes. I have the pedal assembly but need to track down a manual pushrod.
Depending on the tracks I am thinking about doing Drag Week this year as well. I will probably apply to Roadkill Nights again. Beyond that, I don't do any real t&t nights or have any other race plans. There are some local daily driver type races at Milan but my rear tires are too big for the class and don't want to put small tires on it for just one series.
Have started collecting parts to build a mild-ish 540 to replace the 440 currently in the Fury but I don't expect it will be done this year. Still need machinework, custom pistons and most of the valvetrain.
[Re: GY3]
#3201879
01/03/24 09:06 AM
01/03/24 09:06 AM
Posts: 9,882 MI, usa
dvw
MI, usa
Made 125 passes last year. The most I've ever made in the Belvedere since it was first on the track in 2013. Bracket raced, ran Stock S/S events, N/SS. and Open Comp. For the better part of the year the car was very good. The driver not so much. I switched glasses towards the second half and was much better. The .500 pro tree in Open Comp is a on going learning curve. On the practice tree I'm fine, at the track not so good. N/SS we struggled some as well. Deciding on 9.00 or 9.25 index. The weather has to be pretty decent to run 9.00. We tried new ways along with weight to slow down to 9.25. Running roughly 150 lbs with 27 total timing works in some weather. Not great all the time though. Currently rethinling that. To do it all with weight we need to be capable of adding 250 lbs. Did manage two finals, both wins. Along with four semi-finals. Currently adding a larger alternator. The entire motor plate layout needs to be changed to fit. So as soon as the turbo Duster is finished that will be next. Also appears to have a trans leak so that will be addressed. Thinking about the possibility of adding a trans brake for Open Comp and brackets. Looking forward to Great Lakes stk S/S, Buckeye stk S/S, NSS bash, Milan Open Comp, some NMCA and what ever Mopar events pop up. Doug
[Re: Brad_Haak]
#3201884
01/03/24 09:32 AM
01/03/24 09:32 AM
Posts: 2,937 A shed in England
Tig
A shed in England
No racing for us in '23 after waiting for engine parts and a house move. We bought a property but still haven't moved, it needed more work than we first thought. We did get all the engine parts we needed which included some new 600-13 X heads for the 655 engine. The 580 motor was rebuilt / refreshed after nipping a ring land in late '22. This occurred after the head warped, allowing #3 cylinder to pull in oil via a head stud. It still ran a pb of 9.51 prior to that. We had to skim the heads 0.010 which has now upped the C/R from 12.5:1 to almost 12.9:1, the heads are 572 -13 and this must be the 4th time they have been skimmed. 2023 plan is to do a couple of meetings with the 580 to make sure all is well, see how it performs and then fit the 655 for later in the season to try for 8's N/A with a 4000lb race weight.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: dvw]
#3201885
01/03/24 09:40 AM
01/03/24 09:40 AM
Brad_Haak
Loudoun County, VA
I have some options: Mason-Dixon runs a limited "Street Car" series; UNSS runs at Cecil County; Capitol has regular Friday Nights and some Index races scheduled; MIR has some speciality events that I like. However, I don't see myself doing any track's weekly bracket program at this point. I'll pick and choose depending on which car suits the program better, but I need to get some on-track time w/ the old car simply because so much has changed that it's basically a new combination to sort out.
I tried doing two classes w/ the 1320 and not sure that worked to my benefit. It got me more seat time & hits on the tree, but that car doesn't hot-lap well which made it really tough to dial in accurately going back-to-back rounds. Making an 1/8 pass and coming right back to the lanes for a 1/4 pass 5 minutes later (or vice versa) totally screwed me up on how much it was going to slow down on the subsequent run. I need to check the various tracks' schedules and see what's in the plans.
[Re: Brad_Haak]
#3201902
01/03/24 11:55 AM
01/03/24 11:55 AM
Posts: 567 Sth.IL
dare_dude
Sth.IL
Looking forward to racing this year never got out last year. Besides motor rebuild a lot of other things going on. God willing 24 is better year.
[Re: dare_dude]
#3201905
01/03/24 12:00 PM
01/03/24 12:00 PM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
If I do any racing at all this year, I'll probably do 1 or 2 of the King of the Street races.
[Re: an8sec70cuda]
#3201907
01/03/24 12:06 PM
01/03/24 12:06 PM
Posts: 4,699 On the parachute mount
n20mstr
If I do any racing at all this year, I'll probably do 1 or 2 of the King of the Street races. Hope to see you there , i plan on making all of these races in 2024
....BAD A$$ STREET CAR.....
[Re: Brad_Haak]
#3201909
01/03/24 12:12 PM
01/03/24 12:12 PM
Posts: 17,912 S.E. Michigan
ZIPPY
S.E. Michigan
Not sure how much longer the restoration phase will last, but am enjoying not being in a rush.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3201915
01/03/24 12:30 PM
01/03/24 12:30 PM
Posts: 4,584 Motor City
6PKRTSE
Motor City
All my stuff is expired except for cage/chassis. Window net, seat belts, fire suit, helmet etc. I will probably just do No E.T./No Prep/Back Half stuff since there are no rules for certs.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: ZIPPY]
#3201920
01/03/24 12:53 PM
01/03/24 12:53 PM
GY3
Wichita
Not sure how much longer the restoration phase will last, but am enjoying not being in a rush. The hard work is all finished, Rich!
[Re: GY3]
#3201928
01/03/24 01:15 PM
01/03/24 01:15 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Ill be back at running S/ST before the years is over. Truck is ready minus some cosmetics I need to touch up but track time is an issue out here for sure to get it ready to run competitively. The is in pieces making some engine changes and such. Hopefully be back together before summer, but I don't race it much anyway. And we will be running the heads up car until St Louis NMCA then it comes apart for some big changes. But we hope to be able to make Norwalk and Indy with it. We will be in "limp" mode til then as she's been in thetre for a bit.
