Page 1 of 3 1 2 3
440 six pack stock rods crank gram weight ? #3198571
12/19/23 12:13 PM
12/19/23 12:13 PM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Does anyone know the bob weight of a 1973-1974 six pack rods 440 crank ? i have heard it is around 2700-2900 grams in stock form, i know this question has been asked before but i can't remember the ad. thanks to all,,,,,,,,, only check one time a day.
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3198755
12/19/23 10:23 PM
12/19/23 10:23 PM
AndyF Offline
AndyF  Offline
The rotating assembly in those engines is heavy. Heavy rods, heavy pistons, heavy pins, heavy rings, etc. Bobweight is often over 3000 grams. They rev like a tractor!
Re: 440 six pack stock rods crank gram weight ? [Re: AndyF] #3198846
12/20/23 11:53 AM
12/20/23 11:53 AM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
I was thinking it was in the heavy range, i have a NEW eagle crank , but it is #2550 grams, i can use it but i don't want to pay $1,000 to 1,250 for pistons ..........that is too much for a street car......lol.
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3198930
12/20/23 05:55 PM
12/20/23 05:55 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
2550 Is well below the bobweight for a heavy rod set up. Ain't no marrying them together without mallory.
2900 sound about right from memory. I could check but I don't know if I have any pistons around.
What the heck piston are you looking at for that kind of money?
Re: 440 six pack stock rods crank gram weight ? [Re: B1MAXX] #3199084
12/21/23 11:50 AM
12/21/23 11:50 AM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Thank you for looking, diamonds are $1,350 now , looking for a dome piston running a #88cc head, i can get a speed-pro dome but looking for a lighter set, where i live...... it is tuff to get anything done, machine work is the main thing,...................about ready to go to a stock steel crank. some pistons are 9.7 comp that does not do a thing for me. lol
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3199098
12/21/23 12:50 PM
12/21/23 12:50 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Check ross,srp, or icon.
Re: 440 six pack stock rods crank gram weight ? [Re: B1MAXX] #3199104
12/21/23 01:06 PM
12/21/23 01:06 PM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Icon/srp/wiseco/ diamond /ross ..................... I have checked and #1 are cheap heavy dome speed-pro all are flat tops, with no comp # numbers with a #88cc head , but the pricey dome pistons, my luck ,...... if anyone has a solution ( piston wise) please pm me,............
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3199144
12/21/23 02:36 PM
12/21/23 02:36 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
What about getting a lighter set of of H beam rods , the stock 6pak rods were a bad idea , hemi sized rods with little LY rod bolts. Also cut the heads down to a smaller chamber ?
Re: 440 six pack stock rods crank gram weight ? [Re: JohnRR] #3199385
12/22/23 11:57 AM
12/22/23 11:57 AM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
I cut #100 thousand off the # 452 heads on another motor , that many be a route for me, i checked on rods Thursday and they are 809 grams for a steel one, don't know how much six-pack rods weight ,.......... since you can't get what you want you have too compromise , sounds like life !! lol
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3199866
12/24/23 04:22 PM
12/24/23 04:22 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
one random six pac rod
926gr
656 big
270 little
Re: 440 six pack stock rods crank gram weight ? [Re: B1MAXX] #3199966
12/25/23 01:42 PM
12/25/23 01:42 PM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Now that is CRAZY ! but they work ,........thanks for the info,......................LOL
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3200056
12/26/23 10:40 AM
12/26/23 10:40 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My friend bought a 66 Satellite racear. It ran decent. Decided to lash the valves. It had stamped steel rockers. So obviously a hydraulic cam. It also has a 6 pac balancer. Hew was told TRW /Speedpro type piston. Wiyh that balancer it has to have 6 pac rods as well. So it's all old school and heavy. Easily runs 11.40s and has dipped into the 11.30s. He runs it to about 6300. For the street I wouldn't worry about bob weight being heavy if you have the parts already.
Doug
Re: 440 six pack stock rods crank gram weight ? [Re: dvw] #3200061
12/26/23 11:16 AM
12/26/23 11:16 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I'm not knocking them. I just didn't think they would work with 2550.
You would need a piston/pin in the 790gr area. The stock piston/pin is somewhere in the 1000gr area as I can remember. I don't have a piston to weigh though.
Re: 440 six pack stock rods crank gram weight ? [Re: B1MAXX] #3200064
12/26/23 11:41 AM
12/26/23 11:41 AM
U.S.S.A.
U.S.S.A.
You are correct , trw replacement pistons are 1000-1100 grams , piston/pin
Re: 440 six pack stock rods crank gram weight ? [Re: JohnRR] #3200234
12/27/23 11:45 AM
12/27/23 11:45 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I have a stock piston I’ll weigh. I know the pin is bigger and heavier than a stock one. I also have a 74 motor home 440 (never apart) that has 6pac rods, flat tops, steel crank and a regular balancer.
Re: 440 six pack stock rods crank gram weight ? [Re: cudaman1969] #3200254
12/27/23 12:58 PM
12/27/23 12:58 PM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Do you guys think that if i buy a set of LIGHT Wiseco dome pistons /new crank bob weight (# 2550) / LY 440 rod in a +30 over block will it work in a street car with no balancing issues ? thanks for the input !!
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3200275
12/27/23 02:39 PM
12/27/23 02:39 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Random ly rod
607gr big
239gr little
Stock bearing 58gr one set
rings 1/16-3/16th 62gr.
looks like you would need a piston/pin in the 916gr range.
Re: 440 six pack stock rods crank gram weight ? [Re: B1MAXX] #3200281
12/27/23 03:09 PM
12/27/23 03:09 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
looks like a ross 80762 with a standard pin (225g) would be real close.
On their website they list the pin as 158 but that has to be a typo, only the .990's are that light.
Re: 440 six pack stock rods crank gram weight ? [Re: B1MAXX] #3200415
12/28/23 09:06 AM
12/28/23 09:06 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
If that eagle crank is new and has never been balanced its probably not 2550 exactly or at the right place. There is a difference between "target bobweight 2550" and balanced to 2550.
Re: 440 six pack stock rods crank gram weight ? [Re: B1MAXX] #3200494
12/28/23 01:52 PM
12/28/23 01:52 PM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Thanks I see your point, i got a card with the eagle crank with the weight, ???? you are right hoo know's ...................a bunch of trouble. with parts ! ............LOL
Page 1 of 3 1 2 3
