Re: 5 speed install
[Re: flyman]
#3198383
12/18/23 01:19 PM
12/18/23 01:19 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What year Dakota? Some used the NV2500 (NP535). Had one behind a 360 LA...smoothest shifting trans I ever had but was worried it might not survive long so I replaced it with a Tremec TKO600.
Re: 5 speed install
[Re: flyman]
#3198473
12/18/23 08:46 PM
12/18/23 08:46 PM
Posts: 6,291 nowhere
Sniper
nowhere
Not sure what year the Dak is The trans is an AX15. The truck now has a 270 Hemi with the original bell that the engine came with. .I would like to keep that bell as the motor motor mounts 2 spots in the bell. I was hopeing to hang the 5 speed off the original bell as the 3 speed is now.. Thanks for all the replies and the help. The AX15 belhousing bolts to the trans case in a unique pattern which is nothing like the original trans pattern. AX bellhousing pattern You might be able to fab up an adapter that you can bolt to the original bell and fits the AX15, but I think the plate would have to be bolted with the bolts going from inside the original bellhousing to plate, IOW you'll be drilling out threaded holes.
Re: 5 speed install
[Re: poorboy]
#3198773
12/19/23 11:07 PM
12/19/23 11:07 PM
Sniper
nowhere
I have anAC15 trans out of a 90 Dakota and one out of a 92 Dakota. Neither have a bolt pattern that looks like the one pictured above. Both were held to the bell with 4 bolts, but in a different configuration then the old 833 was.
Unless the OP plans on dumping the clutch a lot, I would not be too concerned about the AX15. The slide rail shift mechanism isn't nearly as nice slamming gears (doesn't shift fast enough) as the old Hurst shifter, but it isn't the 1970s anymore. I don't know what an AC15 is, but all AX15's have that pattern. You probably had an NP535/NV2500 transmission, not an AX15. NV2500
Re: 5 speed install
[Re: poorboy]
#3199618
12/23/23 01:02 PM
12/23/23 01:02 PM
Posts: 16,156 Mesa, Arizona
dart4forte
Mesa, Arizona
I checked the tag on the 5 speed out of my Dakota. It is indeed a New Process A535 (2500) 5 speed. They came in Dakotas from 87-92 according to the Mopar manual transmission guide. The AX 15 (which I was told mine was) was put in the Dakotas from 91 to 96.
Sorry for any confusion. Wouldn’t you need an adapter?
Abe Lincoln
Re: 5 speed install
[Re: dart4forte]
#3199677
12/23/23 04:59 PM
12/23/23 04:59 PM
John_Kunkel
Rio Linda, CA
With the correct factory bell, the NV2500 is a bolt on for any LA or Magnum SB.
Re: 5 speed install
[Re: dart4forte]
#3199761
12/24/23 05:53 AM
12/24/23 05:53 AM
Posts: 10,615 Freeport IL USA
poorboy
Freeport IL USA
Sorry for any confusion. Wouldn’t you need an adapter? Since everything came out of the 1990 Dakota with a 3.9 V6, everything was factory bolted together. As John stated, the bell bolts to any Mopar motor with the small block bolt pattern. The older motors that had the extended crankshafts would probably need a spacer between the motor and the bell to put the trans and clutch assembly on the same plain, to make up for the longer crankshaft hub. The bolt pattern between the trans and the bell are probably transmission specific, but it has pretty much always been that way with Mopar. The NP A 535 (2500) trans has the 4 bolt ears to bolt the trans to the bell, and also only has a round hole for the trans snout to fit into. It would probably be an easier trans to adapt to an older bell then the AX 15 with the specific trans bolting arrangement and the oblong center hole. But that would be my opinion based on nothing other then the 4 ear trans bolt pattern and the round center hole. I have no other Mopar manual transmissions to compare to around here anymore.
Re: 5 speed install
[Re: John_Kunkel]
#3200102
12/26/23 03:27 PM
12/26/23 03:27 PM
poorboy
Freeport IL USA
If the V8 is pretty much stock, and the trans isn't abused, it should do well. Dumping the clutch with real traction is what breaks manual transmissions. Reduce the clutch dumping, and remove the real traction and weak parts can survive. Not all of us beat on things like we used to I know I collected enough broken parts from street abuse back in my younger days that I no longer have that desire. Now its more about enjoying the ride from point a to point b. A manual trans can improve that enjoyment as long as you remember what the weak link is.
