727 aluminum drum, what filter.. #319735
05/16/09 05:07 PM
05/16/09 05:07 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
i have an aluminum drum, so im changinf fluid frequantly.. will a reuseable brass filter be ok or is a paper filter better? i know the aluminum is micro- fine .. also is there an in line filter that can be used ?
thanks guys
Re: 727 aluminum drum, what filter.. [Re: mcat4321] #319736
05/16/09 05:28 PM
05/16/09 05:28 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
the instructions that came with my billet steel drum included ali drum instructions too. TCS advise you to use the dacron filter since it is a finer screening material.
Re: 727 aluminum drum, what filter.. [Re: rebel] #319737
05/16/09 05:38 PM
05/16/09 05:38 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
whats a dacron filter? paper or brass
Re: 727 aluminum drum, what filter.. [Re: mcat4321] #319738
05/16/09 05:48 PM
05/16/09 05:48 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i think there the yellow ones with the white fiber stuff inside.
Re: 727 aluminum drum, what filter.. [Re: rebel] #319739
05/16/09 07:27 PM
05/16/09 07:27 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I use the paper-fiber filters from Mopar, Fram are the same looking.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: 727 aluminum drum, what filter.. [Re: Dartsport540] #319740
05/16/09 08:10 PM
05/16/09 08:10 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Say NO to the brass ... it will let-in tooo much of the fine alum material. Any "paper" material is better.
Another Q to ask here ...what type of band are you using with this drum ?
Re: 727 aluminum drum, what filter.. [Re: dOrk !] #319741
05/17/09 05:29 PM
05/17/09 05:29 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
