Need to mod steering line
#3196160
12/08/23 08:27 PM
12/08/23 08:27 PM
Posts: 4,757 Florida
BDW
I need to mod my power steering line / hose to clear up room to connect the AC line to the compressor. The SS line runs straight down and blocks the compressor port. Would it be possible to bend the line up a little, thinking it might collapse it? Or just get a 45 or 90 AN adapter? Any other ideas?
Re: Need to mod steering line
[Re: BDW]
#3196171
12/08/23 09:32 PM
12/08/23 09:32 PM
Posts: 4,451 Michigan
MarkZ
Worthy
Worthy
Could make up your own from scratch with PTFE line.
[Re: MarkZ]
#3196175
12/08/23 09:43 PM
12/08/23 09:43 PM
BDW
The steering hose is laying on the port, that's a plastic protector cap. I need to add adapter fittings on the compressor, so the steering hose needs to move away quite a bit. Here's a reference pic with the adapters on a compressor.
[Re: BDW]
#3196500
12/10/23 02:53 PM
12/10/23 02:53 PM
Posts: 10,641 Freeport IL USA
poorboy
Freeport IL USA
I need to mod my power steering line / hose to clear up room to connect the AC line to the compressor. The SS line runs straight down and blocks the compressor port. Would it be possible to bend the line up a little, thinking it might collapse it? Or just get a 45 or 90 AN adapter? Any other ideas? Don't know what the top connection of the steel line looks like, but it appears to me that the entire length could be rotated outward, away from the inner fender, and routed on the other side of the plastic tab at the top, and the hose at the bottom and have more clearance all around.
